airbur wrote:Thanks. So far their place has been spared.
glad to hear and hope it stays that way!
Colorado75bronc wrote:Sorry to hear, I'll be helping her tonight get the kitchen table moved, wasn't expecting them to have had the rest moved between yesterday today, and I couldn't help last night, so ill see the mess tonight
Jesus_man wrote:Yikes, what'd the fridge do? Start pumping water into the kitchen?
Call the fridge manf.
kinder wrote:WTF!
76fordbronco wrote:It sux when you do an EFI swap in April and your gas gauge doesn't work when your done. You find this this out only after you fill the new 23 gallon gas tank. Then your driving home from a long day working on a friends bronco to find out that your new 23 gallon gas tank has less than 23 gallons in it. I apparently didn't put 23 gallons in it when I thought I put 23 gallons in it.
Note to self: Fix the Freaking gas gauge!
jtsbronc wrote:76fordbronco wrote:It sux when you do an EFI swap in April and your gas gauge doesn't work when your done. You find this this out only after you fill the new 23 gallon gas tank. Then your driving home from a long day working on a friends bronco to find out that your new 23 gallon gas tank has less than 23 gallons in it. I apparently didn't put 23 gallons in it when I thought I put 23 gallons in it.
No you didn't! !
That does suck, at least it was a warm day !
