It is currently Thu Jun 27, 2024 8:56 pm
Digger's '69 Build Thread
![Post Post](./styles/acidtech/imageset/icon_topic_latest.gif) Re: New Member 69
Thanks for the tip on the 200 amp relay, I like my truck to stay unmelted.
Fri Mar 28, 2014 9:21 am |
Fri Mar 28, 2014 3:31 pm |
http://www.dieselorings.com/1994-1998-f ... relay.htmlA few bucks cheaper, anyways. I'll be getting an extra for the Bronco's winch when I have to get one for the F250. Thanks for the good idea.
Fri Mar 28, 2014 5:18 pm |
Time seems to slow down when I'm working on the switch panel (I'm at about 50 hours invested now), but I'm trying to cover every little detail so it works flawlessly and continues to do so over time.
I finished all the drilling, tapping and o-ring sealing of the relay box: by , on Flickr
Mounted the relay board on a plastic back plane and isolated it with little rubber O-rings by , on Flickr
by , on Flickr
I had to invert the Comm board, Control board and Power supply and mount them to the lid, but you can see it forms a tight nesting of the components by , on Flickr
I tested the signal from the switch panel before proceeding any further
With that working, I wired up the relay control board to the relays and hooked up power (red and white wires) and signal (blue and red striped wires) by , on Flickr
First test run was a success. Now I can get WeatherPack plugs on it and get it in the truck!!!
Wed Apr 02, 2014 10:39 pm |
That is amazing!! What is front heavy on engineering and design amounts to something that is very simple to the end user! I love it!
Thu Apr 03, 2014 3:44 am |
Small Update:
I wired the relay outputs on the accessory board and added WeatherPack connectors for plugging into the vehicle harness later. by , on Flickr
by , on Flickr
by , on Flickr
Completely done!! by , on Flickr
by , on Flickr
by , on Flickr
Fri Apr 25, 2014 1:28 pm |
Next I needed to fabricate a tray to hold two Optima batteries where the old battery tray was. I think God was smiling on me that day, because I had a 304 stainless steel lid from a box that was nearly perfect dimensions. I only had to shorten one side and notch some holes to make it fit. This was a serious shoehorn job to keep the batteries low in the engine compartment. by , on Flickr
by , on Flickr
The tray needed to sit about 0.5" higher than the old one to clear the inner fender. At first I had some plastic spacers, but I decided to try my hand at metal forming using my press and some homemade tools. The results look half-way professional. by , on Flickr
Here you can see how the notches help the routing of the headlamp and turn indicator wiring. by , on Flickr
I re-worked the wire loom and routed the wires to sit in the saddle of the battery tray supports. This gives them about 1" of total room between the bottom of the tray and the supports. by , on Flickr
All bolted in and wiring routing shown coming up from the back corner. by , on Flickr
by , on Flickr
Fri Apr 25, 2014 1:38 pm |
A big part of re-working the wiring harness was adding a proper, modern power distribution block to house the MAXI fuses and relays. When I pulled the box from my Ranger, I left the mount behind because it was welded to the body structure. SO, I had to fabricate some new brackets. by , on Flickr by , on Flickr I took a moment to document the disaster my garage has become. by , on Flickr Then back to work mounting the distribution box. by , on Flickr Next I drilled holes and installed RivNuts to mount the accessory relay box on the driver's side inner fender. by , on Flickr by , on Flickr by , on Flickr
Fri Apr 25, 2014 1:45 pm |
To keep the box watertight, I added O-rings to the stainless mounting screws and RTV'd the RivNuts for good measure. by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
Fri Apr 25, 2014 1:47 pm |
I repeated the process to mount the dual 200 amps relays that will handle battery combine function and provide power to the Anderson connector for the winch. by , on Flickr
by , on Flickr
Lastly I could not find a good place to mount the connection box for the VHX gauges. I settled for a spot under the steering column that keeps it clear of the gauge cluster, ignition switch and my accessory switch panel. But this required another bracket to be fabricated. by , on Flickr
Mounted up with some serious 3M double-sided tape. This is the same stuff the OE's use to attach badges to the exterior of new cars. by , on Flickr
by , on Flickr
A couple of holes later and it's in its new home. by , on Flickr
Fri Apr 25, 2014 1:55 pm |
OMG!!! I hate you!!! I just installed an 8 prong turn signal and it took me 10 days to figure out which 2 wires were criss crossed!!! CRAAAAAAP!!! JK Obviously! Your Bronco and Electrical knowledge and real life actual application has me ![drool drool](./images/smilies/drool.gif) ing with envy!!!! Keep the pics and the explanations coming!!! (feel free to dumb it down for me;)
Fri Apr 25, 2014 3:06 pm |
cravenbronco
Welcome to the club. Very Nice rig
Fri Apr 25, 2014 8:22 pm |
More incredible work!
Mon Apr 28, 2014 1:29 am |
EFI Guy
Awesome build!
I can't wait to see what you end up doing with Mega Squirt. It sure has come along way since I looked at it as an option, and with your skills it should be pretty impressive. I'm not sure how I missed this thread, but it now has my full attention.
Mon Apr 28, 2014 11:49 pm |
CORed77
Joined: Thu Apr 04, 2013 11:37 pm Posts: 57 Location: Peyton,CO
Keep the pictures coming! From the female perspective, are you this organized inside the home as well? Just asking...
Wed Apr 30, 2014 1:33 pm |
Thu May 01, 2014 1:06 pm |
I finally finished the electrical system! I started the final wiring at the power distribution box and worked out from there. Looking at all the ground connections to be made, I added a single point grounding block. by , on Flickr by , on Flickr Then the wiring harness for the accessory relay box was assembled. Here is how I made the twisted pair for the signal wire. by , on Flickr And WeatherPack'd the harness: (I retained the ARB compressor connectors for ease of replacement should something fail.) by , on Flickr While at it, the ARB compressor was re-configured for its new home and an airline fitting added for emergency tire filling: by , on Flickr
Tue May 06, 2014 9:32 pm |
With the underhood wiring done, the dash wiring went pretty quickly. So much so, I didn't take many pictures, but here is the final shots from the fuse panels and main harness. A far cry from the rats nest I started with. by , on Flickr
by , on Flickr
I also put some extra effort in while wiring the VHX box. Every wire was terminated with ferrules to reduce strain and prevent fraying. by , on Flickr
With the wiring done, I needed to build a new dash. Starting with this: by , on Flickr
I began penciling in the various components until everything fit. by , on Flickr
by , on Flickr
The biggest challenge was placing everything in a way that it would clear the heating ducting and wiring harness. It's a tight fit around the steering column. Here's the dash all cutout, mounting holes drilled and sanded. It's not as nice as what other people have done, but it is clean and functional. I will probably do a fancier dash when I build the new stretched body and frame. But I just want to drive the thing right now! by , on Flickr
Tue May 06, 2014 9:42 pm |
The biggest hassle in mounting the dash was working around the old dash. The PO had cut it up pretty bad and there wasn't much left to screw to. I did the best I could evenly spacing the Rivnuts so the dash will be mounted with machine screws instead of sheet metal screws. Here you can see the some of the old dash was attached with what appears to be Liquid Nails. by , on Flickr
First test fit. Thanks to B.O.B. for supplying me with a new glove box door. I'm not sure why the old one was cut up. The truck does not have a full cage. by , on Flickr
With gauges and switch panel installed by , on Flickr
I spent some time testing all the vehicle functions before final assembly. It was nice that everything worked as it should, given the extensive amount of re-work I did and all the new wiring that was added. But with everything working, I was able to get a night shot of the new dash. by , on Flickr
With the wiring done, I decided to celebrate with a motorcycle ride and some KT's BBQ!
Tue May 06, 2014 9:51 pm |
Now your just showing off (And I like it !) ![thumbs up thumbs up](./images/smilies/thumbsup.gif)
Tue May 06, 2014 10:03 pm |
Wed May 07, 2014 12:47 am |
Colorado75bronc
Looks great!!
Fri May 09, 2014 7:17 pm |
More progress:
Due to tight spacing when reassembly dash, I had to further thread and shorten the headlight switch nut by , on Flickr
by , on Flickr
by , on Flickr
Fri May 30, 2014 11:50 pm |
Fitup the trans and T-case by , on Flickr Exhaust header now no longer work, so I was forced to buy shortys by , on Flickr ARB showed up. Time to do gears by , on Flickr by , on Flickr by , on Flickr by , on Flickr by , on Flickr by , on Flickr
Fri May 30, 2014 11:53 pm |
Numbered the bolts so I didn't forget to torque one by , on Flickr
by , on Flickr
by , on Flickr
Fri May 30, 2014 11:55 pm |
Improvised knuckle jig for reaming for high steer by , on Flickr
Big hole by , on Flickr
Adapter fit by , on Flickr
Check extended radius arm clearance with axle assembled by , on Flickr
Make new tie rod for 1-ton TREs by , on Flickr
Ream tie rod end for high steer by , on Flickr
Mill wrench flats into tie rod and test fit by , on Flickr
by , on Flickr
Fri May 30, 2014 11:59 pm |
Whipped out a transmission mount by , on Flickr
by , on Flickr
Reattached spring buckets with 2" spacer. I'll redrill the lower spring mounts 1" inboard. This should make up the 3"/side difference of the full width axle. by , on Flickr
My weld-in tube bungs got delayed by UPS, so I'm sitting around with little to do at the moment. Hopefully I can still get the front axle in soon.
Also talked with my boss and lined up some Bilstien 7100's with a custom tune for Jeep TJ from the old Nth Degree suspension system. This should give me a good starting point since the TJ is similar weight, wheelbase and suspension geometry to my planned suspension.
Sat May 31, 2014 12:09 am |
It'll be a roller soon!
Sat May 31, 2014 7:22 am |
Looks good, you're doing some awesome work!
Sat May 31, 2014 8:29 am |
Well I have been working my rear off and I'm still falling behind schedule. Oh well, not much to do about that.
While I had the front axle out, I decided to do something about the ridiculous amount of positive camber these things have from the factory. I bought some ball joint sleeves from work and went about test fitting several until I found a pair that removed the lash right as they were hitting proper adjustment.
1.5° units: by , on Flickr
Installed with angled washer by , on Flickr
Before: by , on Flickr
After: by , on Flickr
I also needed to cut down my old radius arms to work with the Bronco's package space and suspension geometry by , on Flickr
by , on Flickr
For this project, I decided to ditch the Johnny Joints I had been running for 7 years and switch to a combination of rubber bushings and some new joints I designed which feature an OEM-style construction with boots to keep the crud out. by , on Flickr
by , on Flickr
Fri Jun 13, 2014 11:44 pm |
