www.ColoradoClassicBroncos.com - View topic - Ford 9" big bearing axle housing with 10.5" brakes SOLD
It is currently Fri Nov 01, 2024 12:24 pm
Reply to topic  [ 11 posts ]
Post Ford 9" big bearing axle housing with 10.5" brakes SOLD
Comes with axles, full spool, center chunk (but no carrier or gears), and brakes.
200 OBO
Tue Mar 11, 2014 6:37 am
Post Re: Ford 9" big bearing axle housing with 10.5" brakes
Is it 28 or 31 spline?
Tue Mar 11, 2014 7:21 am
Post Re: Ford 9
Tue Mar 11, 2014 7:30 am
Okay, if the spool is 31 spline and you wouldn't mind selling it separately I'd like it. Thinking about putting it in my 609.
Tue Mar 11, 2014 9:42 am
I'd be interested in the axles if they are 31 spline
Tue Mar 11, 2014 9:44 am
If everybody wants the internals, I would take the housing.
Tue Mar 11, 2014 3:54 pm
UPDATE:
Finally tore it down and looks like it's three splines shy of being really popular.
Axles are 28 spline big bearing.
Which of course means spool is 28 spline. (spool is unusable for its intended purpose)
Brakes are all there and in good shape. Probably needs shoes and wheel cylinders just because.
I previously listed it for 200 without a center section (as I hadn't done my gear swap and locker install at the time).
This work is now being done at Kinder's garage so I now also have a limited slip center section with 3:50 gears.
Would like to get 300 for the whole shooting match but can split it up if different folks want different things.
Let me know !
Mon Apr 21, 2014 8:33 pm
Tue May 13, 2014 4:09 pm
are the brakes disc?
Tue May 13, 2014 11:29 pm
Wed May 14, 2014 2:48 am
SOLD
Sat Aug 23, 2014 11:11 am
32,745,119 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
