It is currently Sat Nov 23, 2024 12:35 pm
Looks nice Matt.
On Tuesday I finally changed my leaking intake gaskets and injectors. I'm surprised it made it to Moab and back as bad as the gaskets were. Took it for a quick spin around town on Wednesday morning, put it to bed and hit the road.
Thu May 08, 2014 5:59 pm |
Drove mine the last 2 days. Never hit the hail but did hit rain. Glad i did the wiper upgrade.
Thu May 08, 2014 6:52 pm |
Pulled the old front axle apart and setup a jig for reaming the knuckles for high steer.
Sun May 11, 2014 12:07 am |
Ordered the first of many parts for the 74. Ordered up the BC throttle cable and kickdown set-up. It's been needed for many many years.
Sun May 11, 2014 5:28 pm |
Unaweep
Installed a new clutch and seal kit on the NP435 and D20 transfer case.
My Bronco was getting 30MPG....in leaking transfer case oil.
J.E.
Fri May 16, 2014 2:00 pm |
Did a revision on the old Drum brakes!
Took the drill and spinning wire wheel to ALL the parts...(that no one will ever see!!!)
I replaced all 4 corners with new:
Wheel Cylinders Brake Pads Rt/Lt Rear Hard lines Rt/Lt Front Hard lines, and hoses Brake Master Cylinder Hard lines down from MC and Bled the system
I have brakes!!!
Fri May 16, 2014 3:18 pm |
Installed new WH stock height coils and put some new to me hubcaps on.
Sun May 18, 2014 9:00 pm |
Colorado75bronc
We need that like button dude! Looks good!
Sun May 18, 2014 9:09 pm |
Amazing what a set of hubcaps will do.
Sun May 18, 2014 9:12 pm |
Looks like a matchbox toy next to your truck, love it.
Sun May 18, 2014 10:20 pm |
Gregg
Mon May 19, 2014 8:54 am |
Friday
My wife helped me get my Radius arms installed correctly - the threaded ends are nice and level now. Previously they were about 2.5 " off - that would have been a lot of bronco lean. Should be a rolling chassis by the weekend! And then if I can get some of my friends time we will drop the engine, tranny , exhaust, brake and fuel lines etc.. Can't wait!!!
Mon May 19, 2014 8:49 pm |
kbank6
Got my new harness today. Not so painless when the check had to be written......
Fri May 23, 2014 8:26 pm |
installed the BC throttle cable kit. Need to finish the kick down cable and start the rear tank install.
Sat May 24, 2014 10:03 am |
Friday
My wonderful wife helped me get my chassis rolling today!
Sat May 24, 2014 7:29 pm |
Colorado75bronc
Need a like button for that, looks great!
Sat May 24, 2014 11:52 pm |
Nice & clean looking. Keep updating!
Sun May 25, 2014 9:21 am |
Looks great, I'm digging some of the mods I see, plating for the steering box area and different style rear shock mounts.
Sun May 25, 2014 2:16 pm |
Friday
Sun May 25, 2014 4:09 pm |
Picked up the D44 with ARB 4:56 gears from Digger and met the new member Jesse. He's a cool dude and very knowledgable. Looking forward to getting it installed and hanging out with a new brother.
Mon May 26, 2014 1:36 am |
Finished the BC cable install. Major improvement over the stock bellcrank system. Nice having a kickdown that works now. Maybe I'll get around to the gastank install this week.
Mon May 26, 2014 7:27 pm |
Dropped the driveshafts and BC 2:1 exhaust out of the way.
Sun Jun 01, 2014 12:44 am |
Put a few things up today. Thanks 75DBE and Sean for the help.
Sun Jun 01, 2014 5:03 pm |
Colorado75bronc
Dude give me a call next time you need help
Sun Jun 01, 2014 7:44 pm |
They were already here dropping off Christine (my new name for Sean's race car after it decided to move 5' on it's own today).
Sun Jun 01, 2014 8:07 pm |
Colorado75bronc
Lol! Ok just checking
Sun Jun 01, 2014 10:31 pm |
Part 2 Pulled the shifter from the T case and shift linkage from the transmission. Removed the transmission to bellhousing bolts. Loosened the intermediate adapter to transmission bolts. Loosened the transfer case crossmember to frame bolts.
The auto swap is going very slow but at least I know where all of my tools are and it doesn't look like someone blew a car up in the garage.
Mon Jun 02, 2014 12:24 am |
The demons have been exorcised. To say the clutch was toast would be an understatement. I'll take shots tomorrow when the bellhousing and remaining manual parts come off. But a little teaser: throw out bearings should probably not have giant chunks missing out of them and blue tempered steel.
Mon Jun 02, 2014 11:48 pm |
So.... Tell me how the chainsaw helped to pull the trans, don't keep those nuggets to yourself!
Tue Jun 03, 2014 6:00 pm |
It provided motivation. Finish the transmission. Get back to fire mitigation.
Tue Jun 03, 2014 8:03 pm |
