It is currently Sun Sep 29, 2024 11:27 am
[ 19 posts ] |
Emission Inpsection on 76'?
mdurbahn
I would like to remove the smog pump and all the other emission junk off my 76' EB. For a car this old do they only do the tail pipe emission check, or do they still do a visual inspection?
Thanks, Matt
Sat Nov 16, 2013 2:28 pm |
Re: Emission Inpsection on 76'?
You might want to rethink your plan.
Yes, they check.
Sat Nov 16, 2013 6:25 pm |
Yup. Depending on the county they require smog pump, sealed gas cap and catalytic converter.
Sun Nov 17, 2013 12:41 am |
Moab Mike
Sun Nov 17, 2013 9:29 am |
Sun Nov 17, 2013 10:12 am |
Sun Nov 17, 2013 12:04 pm |
mdurbahn
that sucks,,thanks
Sun Nov 17, 2013 6:30 pm |
ok just went and got my emission testing done and renewed my registration on the 76 bronco.
I now have 5 year collectors plates as vehicles 1981 and older now qualify - cost me $199 which is well worth it.
In order to qualify for the 5 year plates you will need an emissions test done in the last year...
BTW had to go to a new independent emission inspection place as Jerrys on Wadsworth is no longer in business.. The new place I went to on Federal didn't ask me one question except for what year the Bronco was. They look for the smog/air injection, cat and sealed gas cap.
Thu Dec 26, 2013 2:13 pm |
Thu Dec 26, 2013 7:03 pm |
Just renewed my 5 year plates. $231 in Arapahoe Co.
Fri Feb 21, 2014 4:46 pm |
Was excited to see my registration renewal notice in the mailbox today as it indicated EMISSION TEST NOT REQUIRED.
Tried to renew on line only to be told that Collector Plates aren't eligible.
Mon May 05, 2014 8:19 pm |
Unaweep
Not saying anything, but when I lived in Abq, NM it was possible to pass emissions at a few places if you knew who to ask for. I bet there are a few places similar in Colorado.
Just saying......
J.E.
Wed May 07, 2014 10:55 pm |
Really in Denver there aren't. There are only a couple of independent inspection stations left. The rest are state run and good luck if they know a hole in the ground from an engine and what should be on it. Hopefully the independents will stay open for a while longer or at least until all classic broncos are close to except.
Wed May 07, 2014 11:27 pm |
trei75bronco
Joined: Wed Jan 26, 2011 10:55 pm Posts: 837 Images: 0
Take it to one of the independent tail pipe test shops. They rarely pop the hood.
Jerry's emissions
Sun May 11, 2014 7:49 pm |
Sun May 11, 2014 8:51 pm |
Bronco Karma in full force today........
My renewal notice indicated that an emission test wasn't required but I couldn't renew on line when I tried.
I stopped by the DMV and they renewed it no questions asked. After I had the new tag and registration in hand, I asked if I was exempted because I drive by the road side sniffers so frequently. She responded that that they had decided to grandfather the valid plates back to the rules that were in place when the plates were issued.
I will now resume smiling for the rest of the day.
Mon May 19, 2014 10:47 am |
Moab Mike
Now that makes one 76fordbronco happy!!!
Mon May 19, 2014 11:52 am |
Arbitrary & random changes to regulations? Is Obama the Governor of Colorado now?
Mon May 19, 2014 12:14 pm |
C'mon Gunni. They didn't make collector plates mandatory and then raise the prices by 300%.
Mon May 19, 2014 12:20 pm |
[ 19 posts ] |
