www.ColoradoClassicBroncos.com - View topic - 351 EFI swap is a go.
It is currently Wed Jun 26, 2024 5:07 am
Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
Post 351 EFI swap is a go.
Here we go, this is way above my level, but I am going to give it a go. Here is the plan:
94 roller 351
Gt40 heads
Lightning lower intake
Explorer upper intake
Explorer ecu
Coil set up
That's the very basics I know there is a lot to it. I have been following a couple of builds on classic broncos and I am copying them. Wish me luck. Here is a pic of my new old 351 that I just bought.
TJ
F. Scott Fitzgerald
Tue May 13, 2014 12:16 pm
Post Re: 351 EFI swap is a go.
Woohoo!
Tue May 13, 2014 12:22 pm
Still searching for the "LIKE" button thumbs up
Tue May 13, 2014 1:44 pm
Following with much interest
Tue May 13, 2014 3:53 pm
I'll be watching. Good luck, sounds like a great set up! I've got everything ready for a 351, just need time & money for a rebuild.
Tue May 13, 2014 5:14 pm
Didn't do quite the swap you are planning, but if you've got any questions, I just went through this. Good luck. Looking forward to seeing the progress.
Tue May 13, 2014 5:36 pm
Cool!
Since you're in Thornton, feel free to drop by if you need to measure anything or check clearances before installing. I have a '94 351W roller as well.
I'm at 128th and Quebec.
Tue May 13, 2014 8:51 pm
Awesome!
Tue May 13, 2014 9:28 pm
Definitely following this one. Your engine setup is exactly what I want to go to at some point. Unless Kirk finds a magic way to quiet down his 4bt, then I want that.
Tue May 13, 2014 9:39 pm
Wed May 14, 2014 6:06 am
Digger I am also at 128 and Quebec. I am surprised I have never run into you.
TJ
F. Scott Fitzgerald
Wed May 14, 2014 10:47 am
This will be a slow process, but I will keep this thread up to date.
TJ
F. Scott Fitzgerald
Wed May 14, 2014 10:51 am
Hey i drive right by 128th n quebec a lot.
Wed May 14, 2014 7:07 pm
I have been reading about the explorer cam sensor. What is the advantage of using the coils. Can I use a 96 or new distributor with obd2 with an explorer ecu? If you can it seems easier rather then getting a collar fabricated for the cam sensor and figuring out how to hold the thing down. I am going to the junkyard soon so I want to figure out exactly what to pull.
TJ
F. Scott Fitzgerald
Thu May 15, 2014 3:06 pm
There is no way to run a distributor and have the PCM control it with the Explorer PCM. The coil pack setup is a hotter spark, more reliable, and more accurate than a typical distributor. The only downside is the need to fabricate the collar for a 351.
I do have some detailed blue prints to make one, which can probably just be done on any lathe. I was quoted $100 each to have them made unless I purchased a bunch of them. A few guys have had them made for around $75. Recent discussions lead me to believe that someone else may start selling them on CB in the $50 range. So, they may even hit production before your engine is done.
Thu May 15, 2014 6:00 pm
That answers that question. When I go to the yard I will get the coil setup. Thanks
TJ
F. Scott Fitzgerald
Thu May 15, 2014 6:13 pm
I would hold off on purchasing coil packs for now as well. I may have a better solution than the Explorer coil packs, but I want to get some more testing miles on them before I give anyone the green light to run them. I would try to find the 3.8 cam sensor while you're there though.
Thu May 15, 2014 7:31 pm
I will look for one. Thanks
TJ
F. Scott Fitzgerald
Thu May 15, 2014 7:56 pm
Just bought a gt40 lower from a lightning off of ebay. These are getting hard to find.
TJ
F. Scott Fitzgerald
Tue May 27, 2014 7:11 pm
Nice. I stashed one away a couple years ago.
Tue May 27, 2014 7:13 pm
Tue May 27, 2014 8:34 pm
Tue May 27, 2014 8:35 pm
I would be in let me know
TJ
F. Scott Fitzgerald
Tue May 27, 2014 9:04 pm
I want 2 for myself as well. So I'll check to see if the original designer ever decided to have a batch ran off or not. If not, let's see what your guy says. I can get them for a decent price, but only if I buy 50 of em.
Tue May 27, 2014 9:32 pm
+4 for me.
Tue May 27, 2014 10:50 pm
Maybe he could make the tall hold-down clamp too ?
Wed May 28, 2014 4:32 am
I'd be in for one as well.
Wed May 28, 2014 7:31 am
ok i just need the detailed schematics and i can run them over during lunch one day.
Wed May 28, 2014 8:00 am
I can also ask Mike (777mech) he has that spiffy new mill he's playing with.
Wed May 28, 2014 4:21 pm
Heads up. I have a couple being cranked out now. If they pass the muster for EFI GUY were in like flynn for cheap!
Sun Jun 01, 2014 7:10 am
30,942,366 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
