Register •
FAQ
• Login
It is currently Fri Nov 01, 2024 8:41 am
[ 1 post ] |
Need a couple of C4 parts
Need the small rod for the throttle valve that installs behind the transmission vacuum modulator.
Also need the vacuum modulator retainer, small piece of spring steel that mounts to the intermediate adapter and holds the vacuum modulator in place.
Fri Jun 20, 2014 10:06 am |
[ 1 post ] |
Users browsing this forum: No registered users and 69 guests |
