It is currently Sat Nov 23, 2024 3:22 pm
BOBS 2 68S
In the last 2 weeks I installed a 1 inch body lift, new oil pump, crankshaft scraper, clutch, and a twin stick shifter. Note lifting a 40+ year old and very rusted body created more problems, big rust crack on cowl just got bigger. Next will be to do something with the cowl.
Sun Jun 08, 2014 5:57 am |
Unaweep
In the last month, rebuilt the NP435, installed a seal kit for the D20, new clutch in the 351w.
Pulled off the Holley fuel Injection, installed a new Holley Street Dominator intake manifold for a spreadbore carburator.
Installed a Q Jet carburator, new carter electric fuel pump, new fuel lines and filters.
I am so ready to drive this thing!
J.E.
Sun Jun 08, 2014 11:30 am |
Finished bolting up the C4, D20 and driveshafts. Still need to get the auto column, cooler and lines, and linkages installed.
Sun Jun 08, 2014 3:37 pm |
Sun Jun 08, 2014 8:08 pm |
Ah yes. Thanks. That was fun, finding the correct vacuum modulator.
If shopping at Auto Zone, ask for a 1977 Bronco as the 73-76 options only return vacuum modulators for FMX and C6 transmissions.
Sun Jun 08, 2014 8:21 pm |
Since Moab I have been too busy with work and yard work to do much other than an occasional trip to the froyo with the kids...............
Installed mount for iPad Mini
Installed new turn signal switch. I should get fewer dirty looks for not signaling.
Installed upper bearing on the steering shaft. This fixed the slop and amazingly enough eliminated the vibration I was feeling in the wheel at certain speeds.
Before and after pics
Sun Jun 15, 2014 6:03 am |
iPad mini= navigation and music?
Sun Jun 15, 2014 8:34 am |
Sun Jun 15, 2014 9:10 am |
Gregg
Nice. A few extra holes and different stain made the wheel pretty sweet.
Sun Jun 15, 2014 9:13 am |
How does the mount attach?
Sun Jun 15, 2014 9:14 am |
Sun Jun 15, 2014 1:37 pm |
Sun Jun 15, 2014 2:02 pm |
Sun Jun 15, 2014 2:04 pm |
My Dad reports that he opened the shipping container, as he's done every couple months, connected the battery, turned the key to prime the pump and one little bump on the starter and she roars to life each and every time! Makes me feel awful good for the given situation!
Tue Jun 17, 2014 1:51 am |
Shimmed and fit my doors today with the help of HockeyDad. Not perfect but works for me!
The more exciting news is I drove to HR and back with no vapor lock issues!
Sat Jun 28, 2014 7:24 pm |
Mon Jun 30, 2014 2:09 am |
BNC04
In the last couple of weeks, Installed the bumper and tire carrier. Thanks Justin and Kirk! Painted Bumper and sliders. Thanks Justin ! Painted and installed inserts Swapped out old coil springs and shocks with Bilstien and WH 3.5 Coils. Then the wife stole it ! Brett
Mon Jun 30, 2014 9:06 am |
Looks great all put together.
Mon Jun 30, 2014 11:26 am |
Man, you weren't kidding about the flares matching that matte clear. The whole package looks great!
Mon Jun 30, 2014 7:12 pm |
Papa got a new head of hair. Fits like a glove thx Scott!
Thu Jul 03, 2014 7:32 am |
Thu Jul 03, 2014 7:49 am |
Thu Jul 03, 2014 7:59 am |
Does it fit in the garage like that too? It looks really tall in the middle.
Thu Jul 03, 2014 12:42 pm |
its does fit - but by a hair
just a different angle - not my garage... wish it was..
its actually pretty level.. slight bump up top
Thu Jul 03, 2014 1:40 pm |
Which top is that?
Thu Jul 03, 2014 2:08 pm |
cravenbronco
Took old stock water pump out and installed a high efficiency water pump it dropped it 20 degrees compared to the original in temp.
Thu Jul 03, 2014 2:42 pm |
Moab Mike
Thu Jul 03, 2014 5:41 pm |
Thu Jul 03, 2014 8:54 pm |
Nice! Looks great.
Thu Jul 03, 2014 8:56 pm |
Finished the 23gallon tank install. Put a few gallons in it to make sure it works and went for a drive to get dinner. Got a lot of attention at dinner with it.
Fri Jul 04, 2014 7:59 am |
