It is currently Sat Nov 23, 2024 4:00 pm
I drove it to Johnstown Friday afternoon and back home yesterday when it was 95 degrees out.
I really love this drivetrain gearing combination as I can run down the hiway very comfortably. I have a bit of a vibration in the chassis at 65 ish but it smooths out at 70. It really runs super smooth at 80 -85.
All the while, the engine temp didn't get above 200 and the tranny was always at 190 or lower.
Only thing missing is A/C.
Sun Jul 06, 2014 11:23 am |
That's what vent windows are for. :)
Sun Jul 06, 2014 2:19 pm |
Transmission is bolted back up to the bell housing, torque converter to the flex plate, and starter is installed. Not bad for a one armed dope head. I credit the new transmission jack for the ease of reinstall.
Sun Jul 06, 2014 8:34 pm |
Pulled Drews out of the garage to clean the underside before we start tearing into to C-4 to get to the parking prawl this afternoon.
A little degreaser and a pressure washer - amazing how much crap and crus was on the drive way when we were done (damn boy, you only drove her a few months, how did you get it that dirty?)......
Never mind, that was a rhetorical question.
Mon Jul 07, 2014 4:23 am |
Tired of seeing TO languishing in the driveway, I jury rigged the shift rod to the control lever on the column and drove it out of the driveway and into the yard. Hopefully the WH bushings are more pliable than the Dormans Corey picked up for me.
Wed Jul 09, 2014 8:36 pm |
Today was electrical day
I repaired the wiring to the light on the license plate frame.
Then I disassembled the ARB switches and reconfigured the switch for the compressor so it toggle on in the same direction as the other two. Relocated the switches so I can reach and see them better
Sat Jul 12, 2014 8:55 pm |
Gregg
I hope you didn't put them through the dash speaker holes...cuz that's just tacky.
Tue Jul 15, 2014 9:22 am |
Tue Jul 15, 2014 9:28 pm |
Wed Jul 16, 2014 8:03 am |
Wed Jul 16, 2014 8:08 am |
Got the brake lights working on Terrible One with a little help from my assistant. Gotta love those Ford engineers. Keep the same style electrical connections for the same/similar part? Nah.
Sat Jul 19, 2014 9:23 pm |
Lovely assistant you have there! She's growing up so quickly!
Mon Jul 21, 2014 1:00 am |
I drove the 69 another 300+ miles this weekend from Denver to Buena Vista area and back, ran very well and got about 13.8 MPG on this trip.
And buy the way, the BC top is FABULOUS ;)
Mon Jul 21, 2014 7:24 am |
Drove it today. Altho the engine temp stayed between 180-190 I found the fuel pump cant keep up if i get into it.
Mon Jul 21, 2014 5:26 pm |
Picked up some new ball joints from one. Hope to get those installed this weekend along with another fuel pump.
Thu Jul 24, 2014 9:27 am |
Picked up my fresh rebuilt c4 from Phil last night. Also picked up the 351 collar from D&D last night. Now to aquire the rest of the efi for the 351.
Fri Jul 25, 2014 6:19 am |
Got the tires balanced and rotated.
Shimmy at 65 mph is now fixed
Fri Jul 25, 2014 6:50 am |
Finally got around to installing the old style marker lights in the grill
Fri Aug 15, 2014 8:32 pm |
Rubbing compound, polishing compound, finishing compound, waxed and detailed it
My arms are tired
Sun Aug 17, 2014 6:39 pm |
Inspired by Porky..........
I found a really nice set of American Racing 8.5" wide Vectors. Should be here in a couple weeks.
I'm thinking about running them with some all terrain tires in the summer and put the slots / DuraTracs on when wheeling.
Mon Aug 18, 2014 8:14 am |
D&D72
Always liked the look of those wheels.
Mon Aug 18, 2014 8:50 am |
Colorado75bronc
That'll look awesome on yours!
Mon Aug 18, 2014 12:40 pm |
Got a ticket... Beep Beep.
Tue Aug 19, 2014 9:03 am |
I'll bet the speedometer only said 32mph!!! HA!
Tue Aug 19, 2014 12:30 pm |
Moab Mike
Your very photogenic!
Tue Aug 19, 2014 1:12 pm |
Tue Aug 19, 2014 1:52 pm |
B.O.B.
You gotta hide your plate better.
Tue Aug 19, 2014 5:07 pm |
I took my half cab, hard top, bikini Off this morning.
I ditched the old 3 inch - probably from a jeep - rollbar I was running,
And I put my "new to me" Stroppe, Lookin' Roll Bar in!
Wed Aug 20, 2014 1:56 pm |
Moab Mike
I Finally had time to sandblast my 79 F150 knuckles and brake booster bracket. I got the booster bracket primered and painted but ran out of primer doing the knuckles. I'll finish up tomorrow.
Sat Aug 23, 2014 6:04 pm |
D&D72
pretty!
Sat Aug 23, 2014 6:08 pm |
