It is currently Tue Oct 01, 2024 3:25 am
Re: C4 install woes
Dorman part number 74040 ($3.99) appears to be correct. Not carried in stores. "Help" part number 14041 (Advance $7.49 and Auto Zone $5.99) contains an assortment which may have the correct one.
Wed Jul 09, 2014 3:22 pm |
Re: C4 install woes
I believe the assortment does have it.
Wed Jul 09, 2014 4:32 pm |
C4 install woes
Who has a good technique for installing this thing? Heat? Grease? BFH? Two functioning arms? All of the above?
Wed Jul 09, 2014 7:48 pm |
Re: C4 install woes
Wed Jul 09, 2014 8:40 pm |
Re: C4 install woes
Wed Jul 09, 2014 9:47 pm |
Re: C4 install woes
Would heating it up in hot water or with a heat gun help?
Wed Jul 09, 2014 10:08 pm |
C4 install woes
Perhaps. I'll see tomorrow.
Maybe I'll just leave it on the exhaust manifold for a few minutes. :)
Wed Jul 09, 2014 10:13 pm |
C4 install woes
Thu Jul 10, 2014 2:13 pm |
Re: C4 install woes
1-2 feels very good. A quick, almost unnoticed shift under light throttle, firm and fast under moderate-heavy. Third seemed to take forever to engage but maybe I'm just accustomed to 4.11s, not 3.50s. Shifting from park or neutral is a very loud clunk though.
Thoughts?
Thu Jul 10, 2014 3:31 pm |
Re: C4 install woes
Thu Jul 10, 2014 3:53 pm |
C4 install woes
Yes. Park to reverse is definitely more pronounced. And no shift kit.
Thu Jul 10, 2014 3:59 pm |
Moab Mike
Re: C4 install woes
Play in you rear end? No that's not a pick up line.
Thu Jul 10, 2014 4:50 pm |
Re: C4 install woes
Thu Jul 10, 2014 5:08 pm |
Re: C4 install woes
Check idle speed.
Thu Jul 10, 2014 7:57 pm |
