It is currently Sun Nov 24, 2024 12:23 am
[ 11 posts ] |
B.O.B.
Bronco is dead.
So a few weeks ago I get home from work and everything is hunky dori. I go out the next morning to start it up and no fuel pump. All other electrical is working that is non efi related. I checked fuel pump, checked the fuses and rearranged the relays to see if one of them is bad. Still nothing. I then hook up my code reader and it just buzzes(or constant light, does not go into code checking program). Could my efi be fried and or any tips as what else to check.
Stock 302 with reworked 1990 mustang harness. Ran well for 8 or so months. Most electrics(pump, ecu, etc) less than a year old.
Tue Jul 29, 2014 3:35 pm |
B.O.B.
Re: Bronco is dead.
Ecu is a reman from Autozone.
Tue Jul 29, 2014 3:36 pm |
EFI Guy
Re: Bronco is dead.
Check for power and grounds at the PCM first. If all is good crack the PCM open and look for leaking capacitors.
Tue Jul 29, 2014 5:29 pm |
B.O.B.
Re: Bronco is dead.
Which pins are for power?
Tue Jul 29, 2014 7:03 pm |
Re: Bronco is dead.
From oldfuelinjection.
Tue Jul 29, 2014 7:28 pm |
B.O.B.
Re: Bronco is dead.
Looks like the capacitors on the board are fried. Anybody know someone that can fix this or am I going to have to bite the big one and front for a new ECM . Popped n Kirks and it fired right up. ( thanks again Kirk).
Sun Aug 03, 2014 5:14 pm |
EFI Guy
Re: Bronco is dead.
I've got the capacitors in stock and can replace them.
Sun Aug 03, 2014 5:24 pm |
B.O.B.
Re: Bronco is dead.
How much and when can I drop it off?
Sun Aug 03, 2014 5:57 pm |
EFI Guy
Re: Bronco is dead.
Pm sent.
Sun Aug 03, 2014 6:39 pm |
B.O.B.
Re: Bronco is dead.
It's alive. My new brain is working well thanks to Garry (efi guy) . Now on to the twin sticks.
Thu Aug 14, 2014 4:05 pm |
B.O.B.
Re: Bronco is dead.
Special thanks to Kinder as well for letting me borrow his computer. Ill get it back to you soon. Let me know your work schedule and I can drop it off.
Sun Aug 17, 2014 10:53 am |
[ 11 posts ] |
