Upper steering shaft
Postby Justin » Tue Jan 11, 2011 3:35 pm
Pulled the steering wheel today to check out something with the wiring. Discovered that the PO stripped most of the threads for the bolt that holds the steering wheel on. Not sure what my options are. I looked around at the major online sellers, didn't see an upper steering shaft replacement. Any suggestions as to where to start on this one?
Re: Upper steering shaft
Postby HorseMan » Tue Jan 11, 2011 9:17 pm
I think I have a full length one in the garage. Or it can be cut down a bit, also have steering u joint.
HorseMan
Postby Justin » Wed Jan 12, 2011 10:15 am
HorseMan, I've PMed you. Classic, not sure why I didn't think of that. I may opt to go that route as well. Thanks!
