www.ColoradoClassicBroncos.com - View topic - Wheel studs
It is currently Fri Sep 20, 2024 11:50 pm
Reply to topic  [ 14 posts ]
 Wheel studs
Post Wheel studs
I'm switching to alloy wheels from steel and they're thicker. I'm assuming I need longer wheel studs. How much stud needs to be engaged to be safe? Just need to figure out how long a stud I need to buy.
Thu Sep 11, 2014 2:40 pm
Post Re: Wheel studs
you're killing me.
Thu Sep 11, 2014 3:05 pm
If you know what I mean...
Thu Sep 11, 2014 4:28 pm
I was wondering how fast this would go there. :-)
Thu Sep 11, 2014 4:29 pm
Enough to get your nuts tight without bottoming out.
There
Thu Sep 11, 2014 4:45 pm
So if I run open ended nuts I can use really long studs?
Thu Sep 11, 2014 4:58 pm
Thu Sep 11, 2014 9:36 pm
Since most of us use 1/2 inch lug nuts you need about the same for engagement to be safe. Usually if you get at least 8 full turns you are good. Open end or closed won't really matter. Usually the stock studs will be sufficient.
Fri Sep 12, 2014 6:39 am
But in a serious note, you don't want them so long that you can catch rocks on them.
I would go with a length that protrudes 5/8" beyond the wheel. Are the new wheels lug-centric? I hope so. Flat lugs needed checked almost daily on alloy's! I ruined a set in high school.
For that matter, I have also damaged my lug-centric beadlocks as well...
Fri Sep 12, 2014 8:10 am
The new wheels are lug-centric. Just remembered a second question on the same topic. With my current lug nuts I can't get a socket into the very narrow area that the lugs reside in. Is the usual solution smaller lug nuts or a thin walled socket?
Cue Gregg....
Fri Sep 12, 2014 11:13 am
Still not taking the bait....but you guys are making me laugh.
---Gx3
Fri Sep 12, 2014 11:24 am
Thin wall sockets.
Fri Sep 12, 2014 11:49 am
Cool, thanks.
Fri Sep 12, 2014 12:40 pm
Thin wall socket or worst case the crappy spline drive lug nuts
Fri Sep 12, 2014 10:49 pm
32,298,236 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
