Register •
FAQ
• Login
It is currently Fri Nov 22, 2024 6:41 am
[ 8 posts ] |
Woodscaper
Joined: Fri Nov 19, 2010 11:16 pm Posts: 587 Location: Lakewood/Green Mtn.
rear diff question
I swaped my ARB into a new housing and got it all put back together. Why is it that when I rotate the axles the drive shaft does not rotate? What am I missing??
Fri Sep 12, 2014 8:00 pm |
Re: rear diff question
Wait, what? So up on jack stands, xfer case in neutral, ARB engaged and rotating tires & the driveshaft isn't turning?
Fri Sep 12, 2014 8:19 pm |
Also, is this with the ARB engaged?
Fri Sep 12, 2014 8:22 pm |
Woodscaper
ARB not engaged, t case in gear, trans in park and the axles rotate (yes up on jack stands) wtf?
Fri Sep 12, 2014 8:29 pm |
they are supposed to. if you rotate the passenger forward the driver will travel in reverse. Lock the arb and try it again.
Fri Sep 12, 2014 8:51 pm |
or lower one tire on the ground and try again.
x2. Works exactly like an open diff when open.
Fri Sep 12, 2014 9:22 pm |
Woodscaper
Thanks Rob, I was thinking to much about it to see the obvious.
Fri Sep 12, 2014 10:04 pm |
[ 8 posts ] |
Users browsing this forum: No registered users and 26 guests |
