www.ColoradoClassicBroncos.com - View topic - Clutch Support Bracket
It is currently Fri Nov 01, 2024 8:34 am
Reply to topic  [ 5 posts ]
Post Clutch Support Bracket
Looks like a need just one more part to complete the install of Drews brand new to hi.
, NP435 4 speed trans
Called the Clutch support bracket
Mounts on the frame , under the hood on the drivers side frame rail. Looks like it must tie into the engine or bell housing somehow
If you have one, or know where I might be able to source one quickly, please let me know.
This guy right here:
Mounts here:
Fri Sep 19, 2014 11:17 pm
Post Re: Clutch Support Bracket
I probably have it or something that might work your welcome to come look through my pile. After the breakfast I will take a look.
Fri Sep 19, 2014 11:43 pm
That would be awesome. Let me know and I will come to you to grab it if so
Thanks
Sat Sep 20, 2014 6:11 am
I think I saw that on your garage floor!
If you can't find it I believe I've got the entire setup from an auto swap.
Sat Sep 20, 2014 9:01 am
You all are correct, the one in the post above is vote theology I6. Drews is a modern 6 and his set up is for a v-8.
I had the correct bracket here all the time.
Thanks though
Sat Sep 20, 2014 10:16 pm
Users browsing this forum: No registered users and 83 guests
32,742,464 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
