It is currently Mon Sep 30, 2024 6:18 am
[ 4 posts ] |
Saginaw PS pump
I have a pump that appears it won't fit my bracket. The one I have only has one mounting bolt on the backside instead of 2. Let me know if you have one with two mounting points. Thanks!
Fri Oct 24, 2014 7:58 pm |
Re: Saginaw PS pump
I see some instructions there. Can you snap a pic of them?
Fri Oct 24, 2014 8:26 pm |
Re: Saginaw PS pump
Fri Oct 24, 2014 8:44 pm |
Saginaw PS pump
I looked for that. I swear.
Did you pick up that pump new?
Fri Oct 24, 2014 8:52 pm |
[ 4 posts ] |
