www.ColoradoClassicBroncos.com - View topic - Radius arms
It is currently Sun Sep 29, 2024 6:32 am
Reply to topic  [ 17 posts ]
 Radius arms
Post Radius arms
Looking for a set of bronco radius arms. Cheaper the better.
Tue Dec 09, 2014 7:20 am
Post Re: Radius arms
I've got a set. Not sure what they're worth. I think the last set I sold was $50. I think they've got the coil buckets, caps and all the associated hardware, but I can confirm when I get home tonight. Would be willing to trade, esp if you've got a line on a small electric or natural gas shop heater from your HVAC world. If you're building Lars Bars I want to help.
Tue Dec 09, 2014 10:32 am
Tue Dec 09, 2014 4:16 pm
Tue Dec 09, 2014 4:28 pm
I just used a Harbor Freight pipe bender to put a 15 degree bend in a piece of 1.5" 1/4 wall tube, did it no problem. I suspect it'd do the required 7 degree bend easy, but it's not mine so I'm not going to try. You know you want them. Heck, you can use my bigish welder, too.
Tue Dec 09, 2014 5:07 pm
Only tool I dont have to build them is a plasma. I learned a lot when I built the ones on the 79. They are overkill for sure.
Tue Dec 09, 2014 6:12 pm
Got you covered there, too. Whatever the plasma won't cut we can torch cut.
Tue Dec 09, 2014 6:30 pm
Post holiday tech day!
Tue Dec 09, 2014 7:09 pm
Tempting. I've got everything needed to build a set. Anyone need a set of finished Lars bars?
Tue Dec 09, 2014 9:04 pm
X2 for a tech day, I want to build a set for Bubba Smurf.
Tue Dec 09, 2014 11:00 pm
Cool, let's make it happen. I can clean off the fab table and we can do it at my place. Kirk, let's connect beforehand and build a jig. I'll talk to the owner of the pipe bender I've got and see if he's good with us breaking it, I mean using it to bend the tube.
Tue Dec 09, 2014 11:44 pm
Im down for that.
Wed Dec 10, 2014 6:26 am
I'm in.
Wed Dec 10, 2014 7:39 am
Justin lets talk details. I want those radius arms to build this. Sounds like a good build day.
Wed Dec 10, 2014 7:48 am
Wed Dec 10, 2014 7:57 am
My thoughts are to cut off most of the stock arm and just use the "c" portion. and either weld on round tube or square tube and have the bend in those.
Wed Dec 10, 2014 8:40 am
Wed Dec 10, 2014 10:04 am
32,374,692 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
