JGZ
Re: Lar's Bar's Build
I'm in for a pair,possibly two.
Wed Dec 17, 2014 8:00 am |
Lar's Bar's Build
I'm in for 2 sets likely, my Duff arms need new joints so let me confirm the specs.
BTW Hinton has 2x.25 DOM for $11 per foot, they have one stick in stock right now and can get another one locally if needed. If we buy the whole stick we should be able to get a bit better price. I believe the stick is 18-20 foot long.
Wed Dec 17, 2014 9:10 am |
Lar's Bar's Build
I'm in for a 2 set also for my duff arms to replace my cranky joints even though they are 6 months old. Not sure what size I need.
Wed Dec 17, 2014 11:43 am |
Just talked to Duff, the rod ends are 1" x 1.25", both are right hand threads, I'll need to see what the bolt size is that goes through it, it's BIG. I'll also need to check the TPI on where they thread into the arm. http://www.dufftuff.com/1_x_1_25_Diamet ... p/8700.htmDigger, I don't know if Chris and I are the only folks needing these, but if we are then it'd be nice to put them in with the overall order. Anyone else running Duff long arms need new ends? Edit: I also need to measure the ID of the mounting bracket.
Wed Dec 17, 2014 1:07 pm |
$10 says that you're running a 1" bolt (same as Gunni's), and that the threads as 12tpi.
Wed Dec 17, 2014 2:02 pm |
Wed Dec 17, 2014 4:09 pm |
Bump up.
Justin, did you check with any suppliers for brackets? what about a bundle deal with brackets and threaded bungs to weld into the pipe? How about any other prices on DOM?
Mon Dec 22, 2014 7:49 pm |
Nope, not yet. Who would want in on brackets and bungs? I can check about DOM as well. Might get a good deal if shipping isn't too bad.
Mon Dec 22, 2014 9:13 pm |
I'm interested in building a set and would need everything. My problem is I need to also find a set of radius arms. I don't want to de-mobilize my Bronco during the build stage. Anyone have an extra set for sale?
Mon Dec 22, 2014 9:19 pm |
Tue Dec 23, 2014 7:19 am |
Tue Dec 23, 2014 9:09 am |
Tue Dec 23, 2014 10:57 am |
Tue Dec 23, 2014 12:40 pm |
OK, so we've got 2 potential group buys:
1.25" joints: 1. Eck 2. Hockeydad (maybe 2) 3. ZOSO 4. Justin 5. Kinder (likely 2) 6. JGZ (maybe 2)
Brackets 'n' bungs: 1. Justin (brackets only) 2. Eck 3. Hockeydad (maybe 2) 4. ZOSO 5. Kinder? 6. JGZ?
Who have I missed? I'll have time Friday to call around and see who will give us the best deal. I really like Ballistic's brackets, but Artec and Ruffstuff are possibilities as well. Feel free to chime in if you've got a preference.
Tue Dec 23, 2014 1:55 pm |
JGZ
Do we have a final design figured out? I'll be in for both buys X2.
Tue Dec 23, 2014 3:01 pm |
I believe I have brackets that will work, but I'll need bungs.
Tue Dec 23, 2014 3:02 pm |
Depending on pricing..........I might join in both.
Tue Dec 23, 2014 6:52 pm |
Tue Dec 23, 2014 7:55 pm |
The brackets run about $45 per pair, and most vendors will automatically give a 10-15% discount just for asking. I'm guessing we'll get better by ordering multiples of stuff.
Tue Dec 23, 2014 11:12 pm |
Wed Dec 24, 2014 7:15 am |
The updated group buy list:
1.25" joints: 1. Eck 2. Hockeydad (maybe 2) 3. ZOSO 4. Justin-2 for sure, maybe 6 5. Kinder (likely 2) 6. JGZ-2 7. Rox Crusher-maybe
Brackets 'n' bungs: 1. Justin (brackets for sure, possibly 2 sets of brackets and 4 bungs) 2. Eck 3. Hockeydad (maybe 2) 4. ZOSO 5. Kinder-bungs only 6. JGZ-2 7. Rox Crusher-maybe
Additions? I'd like to call Friday for pricing, so please post up!
Wed Dec 24, 2014 12:01 pm |
does landshark want to replace the heims on his duff arms?
Wed Dec 24, 2014 6:06 pm |
Lar's Bar's Build
Wed Dec 24, 2014 8:38 pm |
kbank6
Wed Dec 24, 2014 10:04 pm |
One set of each?
Wed Dec 24, 2014 10:45 pm |
Yes wanted to try different joints
Thu Dec 25, 2014 10:11 am |
casadejohnson
I'm just getting up to speed on this thread. I'm in on the long arm build for sure. I already have a spare set of arms to build. If the price is right, I may do a set for the boys bronco as well. For those who want to build a set of arms but do not want to have the bronco on jack stands during the build , we could make a junkyard run and molest a few F150's for donor arms.
Thu Dec 25, 2014 10:09 pm |
I'd like to make a junkyard run for explorer stuff anyway. Let's set a date?
Thu Dec 25, 2014 10:35 pm |
kbank6
Sat Dec 27, 2014 10:35 am |
