It is currently Sun Sep 29, 2024 11:42 am
[ 7 posts ] |
37" Goodyear MTRs tires, set of 5 with rims - $1275
Moab Mike
Fri Jan 09, 2015 9:11 pm |
Re: 37" Goodyear MTRs tires, set of 5 with rims - $1275
Do they still make this size?
Fri Jan 09, 2015 10:51 pm |
If those tires were any older they'd be able to drive themselves around.
Fri Jan 09, 2015 11:26 pm |
No, this size is no longer made, at least not in a MTR. For some reason people think they're made of gold.
Fri Jan 09, 2015 11:45 pm |
Woodscaper
Joined: Fri Nov 19, 2010 11:16 pm Posts: 587 Location: Lakewood/Green Mtn.
Just like everything else that is highly sought after, you pay top dollar for it.
Sat Jan 10, 2015 2:38 am |
If they are made to the same spec as the set we just took off Bubba Smurf then they'll last forever, those tires were over ten years old.
Sat Jan 10, 2015 8:27 am |
Good tires, but the 15" wheel size are on the uncool list for that size of tire...
Wed Jan 14, 2015 2:58 am |
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 1 guest |
