It is currently Fri Nov 22, 2024 11:42 am
[ 8 posts ] |
Local engine builders/machine shops?
Hawk76
I'm doing a frame off resto on my wife's 76 and looking to see what my options are locally for the engine. Any recommendations on a machine shop or any good long block builders around that may have a deal on a 351?
In Colorado Springs but willing to drive a few hours for the right shop.
Thanks,
Will
_________________ Colorado Springs
Fri Jan 23, 2015 9:41 am |
Re: Local engine builders/machine shops?
MPG heads in englewood. Well known as a solid Ford engine builder.
Fri Jan 23, 2015 10:05 am |
Go see Stan at Rocky Mountain Machine. He is the guy when it comes to Ford in COS. He can point you in the right direction for someone to do the assembly work.
Fri Jan 23, 2015 10:10 am |
ManTruck
D&K in Canon City have been honest and reliable. Always a decent price for me and others.
Danny will do what you want and does well on the pricing of the internals.
_________________ Owned my 1972 since 1985
Canon City, Co
Fri Jan 23, 2015 3:14 pm |
Moab Mike
Fri Jan 23, 2015 5:45 pm |
I just dropped off some stuff for Scott at MPG Heads this morning. I would suggest using him for any machine work you need to do to your block but he does not do any assembly of the parts. He did tell me that he has a buddy that will build it though so I would still suggest contacting him!
Mon Jan 26, 2015 11:52 am |
Colorado75bronc
Stan at Rocky Mountain Machine in Colorado Springs! Great guy and always honest, and guaranteed done very well! Here's his number 1 (719) 591-7915
Mon Jan 26, 2015 9:19 pm |
I had fire do the machine work on my 460. They milled the heads for screw in studs and roller rockers and guides. They also measured for push rods for the roller cam conversion.
Tue Jan 27, 2015 7:10 am |
[ 8 posts ] |
Users browsing this forum: No registered users and 16 guests |
