It is currently Fri Sep 20, 2024 11:31 pm
[ 16 posts ] |
GT40 upper, lower, EGR, and throttle body- 125.00
I've got a GT40 upper and lower intake manifold off of a 96 Exploder. It has the EGR plate/valve attached and the Exploder 65mm throttle body. There are also a few injectors still in the manifold.
I pulled it to get to the GT40 heads underneath and brought it home for resale since I busted my ass getting it off.
I'd like to get 125.00 for the set up as it sit now but I'm flexible. It's just taking up space in the garage.
Located in Colorado Springs but can get it to Parker pretty easily.
Mon Jan 26, 2015 1:25 pm |
TOOLMAN
Re: GT40 upper, lower, EGR, and throttle body- 125.00
I would take the TB if you're willing to separate...
Mon Jan 26, 2015 1:44 pm |
I'll ponder it. Would rather keep everything together as a single package though. In any case, I can go grab another TB from the yard.
Mon Jan 26, 2015 2:13 pm |
TOOLMAN
I completely understand...Let me know if you change your mind. I think the TB I have is a '99 variety without the PCV tube on it. Was out at the UPAP last week and didn't see any earlier model ones. If you come across one, snag it!
Mon Jan 26, 2015 2:34 pm |
Mon Jan 26, 2015 4:26 pm |
Want. Can't buy, but want.
Mon Jan 26, 2015 4:41 pm |
Mon Jan 26, 2015 4:47 pm |
Huh, haven't had that one happen before. I'd take them off your hands if I didn't need to buy a bunch of exhaust parts.
Mon Jan 26, 2015 4:49 pm |
I'm sure I'll be tripping over it at least until tax time.
Mon Jan 26, 2015 4:50 pm |
I'f you've still got them awhile from now I might swing it.
Mon Jan 26, 2015 4:52 pm |
Hmm, maybe I need to look at what it would take to do the swap. I had been planning to just grab a full engine with everything. Probably silk the route to go since my engine needs to be rebuilt. It's seriously lacking on compression.
Mon Jan 26, 2015 7:16 pm |
If that's the case a complete engine swap is likely the better path.
Mon Jan 26, 2015 7:27 pm |
That was my thought too. I'm always looking for a reason to justify more parts for my Bronco though. Guess I should finish the current projects first. :)
Mon Jan 26, 2015 9:18 pm |
In that boat with ya.
Mon Jan 26, 2015 9:45 pm |
SOLD
Wed Apr 01, 2015 6:12 pm |
cravenbronco
I'm starting to hate Colorado.[/quote]
I'm with you on that.....
Thu Apr 02, 2015 8:07 am |
[ 16 posts ] |
