www.ColoradoClassicBroncos.com - View topic - Looking for help pressing out a u-joint
It is currently Sat Nov 23, 2024 1:17 am
Reply to topic  [ 21 posts ]
Post Looking for help pressing out a u-joint
I'm probably premature in this request in that I have not even started diving into this project and I'm an amateur mechanic, so I don't know EXACTLY what I need to do to replace my driver-side front u-joint. But I'm pretty sure it's going and from what I've learned so far, is that I'm going to need to press out my old u-joint and then repress.
This is something I'm not really confident that I could do myself. So I guess I'm wondering if anyone might be willing to help or recommend a place who could do it?
Wed Aug 27, 2014 5:27 pm
Post Re: Looking for help pressing out a u-joint
I've got a press and am happy to help. I'm in lakewood.
Wed Aug 27, 2014 6:04 pm
Where are you located? I've got a press too, down in Pueblo.
Wed Aug 27, 2014 6:13 pm
No need for a press, just a vice and a hammer and a socket slightly smaller than the cap
Wed Aug 27, 2014 6:28 pm
Thats how I lost my last thumb nail. Pretty sure I made up some new curse words that day as well.
Really though, that is right, you can do it with a hammer and a couple of sockets. Pretty easy job.
Thu Aug 28, 2014 6:16 pm
Hey Justin - would love to take you up on that. I'm in Littleton. Thanks to everyone for the tips and offers! I'll PM you Justin - want to know what your schedule is like. Thanks! Mark
Thu Aug 28, 2014 8:48 pm
I recommend against using a press as I have seen many people bend the ears on a driveshaft or axle shaft. A press is overkill for the job. Thats the reason I chimed in.
Thu Aug 28, 2014 9:28 pm
PMed ya back. I can teach you both the easy way with a press and the marginally less easy way with a vice, hammer and socket so that you know how to do it. If nothing else you should know the basic way so you can change one in the field.
Thu Aug 28, 2014 11:34 pm
Agree with Justin. As long as you do it right, both are effective but the press is much easier.
Thu Aug 28, 2014 11:53 pm
x2 on the BFH!
Wed Sep 03, 2014 7:14 am
I just had it looked at, and apparently the u-joints are fine and now I'm stuck wondering where the clanking sound is coming from.. Any ideas? It's there when coasting. Not when accellerating, not when braking. Hope I can figure this out!
Wed Jan 28, 2015 10:49 pm
Does it change in speed, pitch or volume when the truck changes speed?
Wed Jan 28, 2015 11:06 pm
Thu Jan 29, 2015 12:19 am
Where does it sounds like it is coming from?
Thu Jan 29, 2015 12:27 am
is it when you hit a bump? hubs locked in? one very overlooked area that causes people to search and search is the spindle bearings.
Thu Jan 29, 2015 7:20 am
Thu Jan 29, 2015 10:18 am
Thu Jan 29, 2015 10:19 am
It could be there is no change because the spindle bearings are already done.
Thu Jan 29, 2015 10:53 am
Thu Jan 29, 2015 12:30 pm
You could run it in the air on four jack stands, poke around with a stethoscope on the front end and listen for the loudest noise, if it were in the spindle bearings it would be loudest at the back of the knuckle. If it is the spindle bearings you might get lucky and only need bearings, but there is a possibility of you also needing the outer axle stub shafts
Sat Jan 31, 2015 11:42 am
If you do this have someone else in the vehicle to stop it immediately if the stands shift or anything seems out of place
Sat Jan 31, 2015 11:44 am
Users browsing this forum: No registered users and 24 guests
32,963,611 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
