Register •
FAQ
• Login
It is currently Mon Sep 23, 2024 7:22 pm
[ 7 posts ] |
5.0l 50oz inbalance flywheel, clutch, and pressure plate.
rooster
Joined: Thu Feb 12, 2015 8:29 pm Posts: 176 Images: 0 Location: Platteville
selling a lightly used clutch assembly that came off my bronco, the flywheel is the50oz inbalance for EFI roller motors, I took it off because it was interfering with a rib inside my zf5 speed so I had to swich clutches, it was in an NP435 however and worked great. it is a high performance clutch and grabs really good, clutch disk still has a lot of life left. flywheel teeth are pretty good aswell, will also throw in a used starter. let me know if you might be interested and we can work out a price. THANKS!
Sun Feb 15, 2015 8:18 pm |
Re: 5.0l 50oz inbalance flywheel, clutch, and pressure plate
I might be interested.
Sun Feb 15, 2015 8:44 pm |
rooster
pk sounds good, let mw know if you have any questions
Sun Feb 15, 2015 8:46 pm |
Dirtheadz
I'm defiantly interested...
Sun Feb 15, 2015 9:51 pm |
I need to pull my starter and check the teeth on my pressure plate, will let you know. Please feel free to sell if you find another buyer.
Sun Feb 15, 2015 9:57 pm |
sykanr0ng
Everything I've seen say the ZF only works well with diaphragm clutches not the three finger old style clutches. The three fingers don't work right with the hydraulic throw-out bearing.
Mon Feb 16, 2015 12:53 am |
rooster
sold.
Fri Feb 20, 2015 8:08 pm |
[ 7 posts ] |
