It is currently Sun Nov 24, 2024 2:52 pm
[ 16 posts ] |
Doesn't sound right to me, please confirm
I was *reading* about TTB50s, on Pirate (yeah I know), and someone said TTB44 knuckles, hubs, brakes, etc are the same as 78/79 F150/Bronco stuff.
I'd think the knuckles are different.
If they are the same, then there is a new source of disk brake conversions. But someone else would have figured that out by now.
Mon Feb 16, 2015 12:56 pm |
I don't think they are the same either. Maybe a Dana catalog would show the different part numbers. Next time I'm in a yard I'll do a visual comparison.
Mon Feb 16, 2015 1:37 pm |
If I recall correctly, everything from the spindle out (5 bolt pattern versus the drum/Chevy 6 bolt) is the same, or pretty damn close from 1976 on.
Mon Feb 16, 2015 2:10 pm |
Re: Doesn't sound right to me, please confirm
The knuckles are definitely not the same. They don't fit, and the caliper brackets are integrated into the knuckle. I don't know whether the calipers themselves swap. As Zac mentioned, spindle is supposedly the same.
Mon Feb 16, 2015 2:14 pm |
sykanr0ng
Others have looked into this: http://www.fullsizebronco.com/forum/sho ... hp?t=65308Some parts interchange, which can be helpful to complete an axle someone has partially stripped. From the above thread: THINGS THAT WILL SWAP OVER: gears rotors calipers lockouts THINGS THAT WILL NOT SWAP OVER: knuckles spindles (FSB thread says it is six bolt) axle shafts
Mon Feb 16, 2015 2:28 pm |
Mon Feb 16, 2015 6:18 pm |
trei75bronco
Joined: Wed Jan 26, 2011 10:55 pm Posts: 837 Images: 0
I have a little 1st hand with this. The dana 50 outers are more or less a dana 60 out and 44 inner. There are some similarities to a 50 and 60. The knuckles brakes and spindles are virtually the same as later 97 ish ball joint dana 60 stuff. The spindles will fit a earlier Dana 60 but the index ring is smaller due to the brake bracket being cast in on the later ball joint stuff the earlier Dana 60 has a separate bracket so it needs to index thru the knuckle and the bracket. The later 60 and 50 stuff swaps over fine. The inner is not the same as a anything other than Dana 50 from what I have researched
I recall this being true for the solid dana50 axles which no one wants. Sorry saw ttb 50 after
Mon Feb 16, 2015 8:21 pm |
Thanks, I'm reading a lot, but that involves a bunch of posts that are misleading or wrong all together.
At this point, I just want to use as much stuff as I can from the TTB50. It looks like I can use the hubs, spindles, rotors & calipers (although they will be replaced with new). I hopefully gears, but I'm still not sure. I need knuckles from 92-97 ball joint D60, they will work with the TTB50 spindles. That is info posted by Mr. N, the guy with the D44/D60 info sites, so I'm sure that is good info.
I just edited my post above. Apparently TTB50 knuckles have different ball joint spacing and WILL NOT bolt to D60 inner C's. Either I was confused, or a few people posting on a few threads were confused. Or it was a team effort.
Mon Feb 16, 2015 8:53 pm |
trei75bronco
Mon Feb 16, 2015 8:58 pm |
That is one of the threads that got me confused. "Flipped Out" did the conversion with solid axle D50 knuckles, not TTB50 knuckles. He jumps to the conclusion that TTB knuckles are the same as straight axle knuckles. I'm pretty sure he's wrong. There is a Pirate thread about putting Ford knuckles on a Dodge D60, and it gets confusing too. TTB50 knuckles won't fit D50/60's, just like TTB44 knuckles won't fit D44s. I just read this, I think its more reliable: http://www.fordification.com/forum/view ... 53&t=23592
Mon Feb 16, 2015 9:06 pm |
trei75bronco
I'm wondering if they are getting camber and caster confused. Building a ton of either into a knuckle would be a little weird. Caster is almost always on the inner c and how it's oriented on the tube Camber I could see that built in but you can't put in too much. I saw one guy reference the knuckle having toe built in. Lol
Mon Feb 16, 2015 10:35 pm |
trei75bronco
I would look for a solid axle 50 to be safe .02 I've never been a fan of ttb
Mon Feb 16, 2015 10:36 pm |
I think because of the TTB design the knuckles had a bunch of camber built in. They won't bolt to a solid axle anyways, so its all irrelevant. I'm just scavenging parts from the TTB. I'll be welding D60 inner C's to a HPD44 housing. Then using 92-97 D60 knuckles, brakes, hubs, etc, and D60 axle shafts. This ARB 35 spline locker http://store.arbusa.com/ARB-Air-Locker- ... 528C7.aspxWith D50 gears & this kit: http://www.jantz4x4.com//jantz.php?p=detail&pro=jana_54Hows that for a big screwy mess?
Mon Feb 16, 2015 10:46 pm |
Love it.
Tue Feb 17, 2015 7:17 am |
Wed Feb 18, 2015 11:54 pm |
Thu Feb 19, 2015 6:39 pm |
[ 16 posts ] |
Users browsing this forum: No registered users and 18 guests |
