It is currently Sun Nov 24, 2024 7:57 am
[ 11 posts ] |
Stubborn3
Joined: Mon Sep 17, 2012 3:09 am Posts: 174 Location: Denver/Leadville, Coloradical
Wiper arm adjustment?
Probably a stupid question but is there a way to adjust (shorten) the wiper arm on the passenger side so that the wiper blade doesn't contact the lower windshield trim thus destroying wiperblades? I'm using stock blades so I'm not sure why this is an issue all of a sudden... maybe it's always done it?
_________________ '72 sport, 351 Cleveland, NP435, twin-sticked 20, unknown lift- if any, 35" KM2s siped by B.O.B, custom rust and dents, 2 kid seats.
Mon Feb 16, 2015 2:36 am |
Gregg
Re: Wiper arm adjustment?
Good time for a Cherokee wiper arm conversion.
Mon Feb 16, 2015 10:31 am |
That's odd, the original arms used short, like 12" or less, wipers.
Mon Feb 16, 2015 1:39 pm |
I suspect you've got either non-stock blades or non-stock arms. Or both. The wipers on my rig couldn't hit the bottom of the windshield if they wanted to.
Mon Feb 16, 2015 2:15 pm |
I have the Cherokee conversion and use it with 14" blades.
I take a 1/8" off the blade on the passenger side so it clears the bottom of the windshield gasket
Mon Feb 16, 2015 4:51 pm |
Stubborn3
Seemed odd to me... ordered the wiper arm replacements from WH and they clip right on but it looks like the passenger side arm is a bit longer than the driver side. I'de like to convert to something that lets me run better wiper blades so I'm all ears on this Cherokee swap you speak of
Tue Feb 17, 2015 3:42 am |
The conversion involves getting a set of wiper arms off of the rear hatch of a jeep Cherokee and then cutting them shorter.
Once you do this, you can use a 13" or 14" blade.
I have a set of arms you can have for 20 bucks.
Pm me if you want them.
Tue Feb 17, 2015 5:38 am |
Unaweep
Why the conversion? I have stock wipers and went to O'Reilly's auto parts, they had them in stock for cheap (like $9 each) and even put them on in the parking lot.
Erik
Tue Feb 17, 2015 8:34 am |
The Cherokee arm swap allow you to run better wiper blades (larger & modern design) and they increase the down pressure of the blade so it cleans better.
Tue Feb 17, 2015 8:45 am |
Just as Kinder says, they are an outstanding upgrade; the disc brakes to stock Bronco wiper's drum brakes if you will.
Tue Feb 17, 2015 11:18 am |
sykanr0ng
Many years ago I had the solid extension on a factory arm come loose, it hit the windshield frame like you are describing, shortly before it got tossed onto the side of the road by the sweep.
Tue Feb 17, 2015 4:14 pm |
[ 11 posts ] |
