It is currently Sat Nov 23, 2024 9:00 pm
Reply to topic  [ 2657 posts ]  Go to page Previous  1 ... 63, 64, 65, 66, 67, 68, 69 ... 89  Next
Well after almost a year after purchasing the 74' from Zoso the drive train was removed then akaFrankCastle and myself spent the weekend taking off the body and storing it on my utility trailer. After that we removed the axles and steering box. We found some issues with one of the backing plates on the 9" (loose) and everything is in need of a thorough rebuild. Project Roadkill will start when I get back from Vietnam. Current plans are a 3 1/2" WH lift, 4:11 axles, EFI 302, Viperbuilt C4, T/J Dana 20 hybrid, half cab with the option of a Bestop soft top and an AM/FM radio. Once I have it back on the road I eventually intend to install a 351 and a 4R70W.
Sun Feb 01, 2015 11:26 pm
Mon Feb 02, 2015 4:32 pm
Added grill stickers last nightImage
Tue Feb 10, 2015 11:32 pm
Whoa. Don't hurt yourself. Just kidding man. The people I work with have a hard time with those. Of course they're in Kindergarten, but stickers can be tough.
Wed Feb 11, 2015 10:14 am
Final push on the 76.
Spare tire carrier on. Tinted rear glass. Just have to get the trim on and then onto the interior.
Mon Feb 16, 2015 8:03 pm
After seeing it out and about, I assumed you had it finished. What a sharp truck for sure!
Tue Feb 17, 2015 6:37 am
Tue Feb 17, 2015 9:43 am
What, if anything, did you use between the carrier and the painted surface under it on the corner of the truck?
Tue Feb 17, 2015 11:15 am
Tue Feb 17, 2015 12:06 pm
Tue Feb 17, 2015 12:10 pm
Haven't owned one yet that had a spare tire rack mounted. Plan on putting one back on T.O. and the Stroppe modified one day. Just curious if you went straight to the paint or used an isolating piece of any sort.
Tue Feb 17, 2015 12:13 pm
Straight to the paint
Tue Feb 17, 2015 12:51 pm
Just placed my order for a new radiator and trans cooler.
Fri Feb 20, 2015 6:59 pm
Started removing my old Duff drop brackets so I can install the new long arm kit. Forgot how much grinding was going to be involved. I certainly wasn't in danger of anything falling off. Can't wait until I can start welding the new brackets.
Sat Feb 21, 2015 8:55 pm
Profile WWW
Got carried away plowing and drove too hard into a frozen snow bank and broke something. Believe me, it wasn't very hard at all.
Ended up being the welds on the crossmember I built last year when I was using the Lincoln 140. Welds just weren't hot enough and didn't penetrate good enough. The new Miller solved it.
My dad taught me that welding is just like golf, whenever plausible, blame the equipment !
icon biggin
Tue Feb 24, 2015 5:11 am
Glad it was an easy fix! That logic pretty much goes for everything...
Tue Feb 24, 2015 5:19 am
I finally got to use my new to me Lincoln 180 to start finishing up my next project ;)
one thing thats great in a small garage is welding 1/4" plate sure heats it up!
Tue Feb 24, 2015 9:17 am
Tue Feb 24, 2015 2:50 pm
Been having some good fun with the olow the last few days.
Thu Feb 26, 2015 12:37 pm
I dont know why it so fuzzy but late christmas here.
Fri Feb 27, 2015 7:55 pm
Finding new homes for the herd. The HOA has finally had enough of my Don Jr. yard. A little birdie flew by yesterday to let me know I would be receiving a visit from the city Code Enforcement office this week. I can't wait.
Sun Mar 15, 2015 12:24 pm
New thermostat, water pump, fan shoud and a couple of hoses that were on their way out. Need to keep her cool this summer!
Sun Mar 15, 2015 6:10 pm
Mon Mar 16, 2015 7:36 am
Installed new tank. That was a PITA!
Mon Mar 16, 2015 10:16 am
Images: 11
New hoses, new belt, started new WH door rubber set.
Mon Mar 16, 2015 12:51 pm
Mon Mar 16, 2015 1:17 pm
Images: 11
Mon Mar 16, 2015 6:54 pm
Bounces back? Is the window frame fitting correctly inside the half cab opening?
Mon Mar 16, 2015 7:36 pm
Tupperware effect. Landshark has the same thing going on. Truck is so air tight that when you try to close the door the air pressure pushes it back open.
Mon Mar 16, 2015 7:39 pm
A bronco that is air tight, not on my watch! BSD has so many holes that it drains MUD out!
Mon Mar 16, 2015 7:41 pm
32,983,151 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
