It is currently Mon Nov 25, 2024 9:19 am
Project sneak peak.
Been working on my new project a bit - can't take credit for it all but I am customizing it a bit and doing some finish welding before i paint it... Wanted a 18" LED but a buddy of mine needed it and gave me the 2 stage 20" instead.. guess i will live with it ;) Working on getting the new syntheic line and fairlead.. will be drilling one more hole up front to fit a standard 10" hawse fairlead.
Thu Feb 26, 2015 11:01 pm |
Re: Project sneak peak.
That's going to look sharp!
Thu Feb 26, 2015 11:11 pm |
Nice work Chris! Did you and a guy-who-shall-remain-nameless create this from scratch? I want to see what you have on the backside. Consider any hi-lift jacking points? A very nice looking bumper for sure!
Fri Feb 27, 2015 3:34 am |
Nice job Chris,
Been a long time coming for that and glad to see it come about now.
Fri Feb 27, 2015 7:52 am |
That is going to look great - is that for the Red NM Bronco that you have been building for me?
Fri Feb 27, 2015 8:58 am |
Very nice!
Love the LED lighting!
Fri Feb 27, 2015 9:24 am |
cravenbronco
Looks great now I want one lol
Fri Feb 27, 2015 10:40 am |
Fri Feb 27, 2015 10:44 am |
Ahh, I think I ran into his father at a Costco one time after he saw a t-shirt I was wearing. Really looks like some good stuff. I can't wait for more pics!
Fri Feb 27, 2015 12:04 pm |
Looks great! I'm not sure if you need to open up the hole for the winch line any, but if you want to use the plasma we can knock it out.
Fri Feb 27, 2015 1:56 pm |
Fri Feb 27, 2015 4:45 pm |
LESS Sneaky!!!
MORE Peeky!!!
Fri Feb 27, 2015 5:22 pm |
Sat Feb 28, 2015 10:14 pm |
Project sneak peak.
Got everything fitted, drilled and tested. Now onto primer. Paint tomorrow. A little concerned with air flow into the radiator but I will cross that bridge when the time comes.
Sat Feb 28, 2015 11:46 pm |
Just an FYI that marker writing will bleed through the paint also as it did the primer.
Sun Mar 01, 2015 7:23 am |
Sun Mar 01, 2015 9:14 am |
Hammered paint covers a lot of that sort of thing. Or maybe just makes it blend in.
Mon Mar 02, 2015 3:55 am |
Final coat of hammered, didn't like that it was more of a grey - but already knew it would be So decided to make it black - final coat and set to cure for 5-6 days. Seems like it will hold up very well, wish it was warmer but got the garage to 62 F Hopefully get it mounted up toward the end of the week and then move on to the rear tire carrier ;)
Mon Mar 02, 2015 9:30 am |
Yeah, I remember the black coming out more gray as well. But I just went with it...
Looks good and it'll look great installed!
Mon Mar 02, 2015 9:32 am |
Did you use Hammerite?
Mon Mar 02, 2015 10:47 am |
TOOLMAN
That's real nice, Clark...
Mon Mar 02, 2015 10:56 am |
Mon Mar 02, 2015 11:14 am |
I'm using the same stuff on my axles. I like the color for them, but good call on topcoating it.
Mon Mar 02, 2015 11:16 am |
Project sneak peak.
Everything works. Wiring isn't final but it's run for now hopefully get the rest of my parts this week and I can start building my panel. Two more weeks I can pick up my synthetic line and fairlead
Sat Mar 07, 2015 7:12 pm |
What's going on with that drivers side coil?
Sat Mar 07, 2015 8:21 pm |
Sat Mar 07, 2015 9:48 pm |
Moab Mike
That is pure sexy right there!
Sun Mar 08, 2015 7:27 am |
When I first mounted the bumper the body was an inch higher on the passenger-side I had to remove almost half an inch of spacers in the body mount. To get it close. No idea why he had that many shims in the body mount.
Sun Mar 08, 2015 8:30 am |
Looks good. Where are you getting a synthetic line from? Im thinking of going with these guys. http://olympusoffroad.3dcartstores.com/ ... _c_11.html
Sun Mar 08, 2015 8:42 am |
Custom splice. 125' of 3/8" line with all the goodies including hawse fairlead. Slightly less than $500 includes shipping. I priced several places and he's priced pretty good.
Sun Mar 08, 2015 8:49 am |
