rooster
Joined: Thu Feb 12, 2015 8:29 pm Posts: 176 Images: 0 Location: Platteville
Tire rack mounting on drivers side?
Hey all, gonna start building a set of bumpers soon and was wondering why nobody offers the tire rack to be mounted on the drivers side vs the passengers... I would really like the ford logo on the tailgate to show. Anybody see any reason as to not mount a swing out tire holder on drivers side? Thanks
Tue Mar 10, 2015 7:55 pm |
Re: Tire rack mounting on drivers side?
Maybe because of vehicle lean with the driver on that side. Been wondering that myself. I'm going to center mine. Who needs to see out back
Tue Mar 10, 2015 8:08 pm |
rooster
Ya good point... The lean part not the part about not being able to see... But doesn't the whole drivetrain sit slightly to the passenger side? And also generally the battery
Tue Mar 10, 2015 8:10 pm |
My guess is the whole line of sight argument. I do agree that it would be nice to be able to see the FORD decal in the back though!
Tue Mar 10, 2015 9:18 pm |
rooster
Eck I really like your square tube bumpers, what did you do to make the hinge for your tire carrier?
Tue Mar 10, 2015 9:24 pm |
The icon or most of the icons i have seen have a driver side swing out. Makes sense as its out of your view.. but a stocker tire doesn't really block the window too much.
Tue Mar 10, 2015 9:44 pm |
rooster
Ya so far I don't see any negatives as to mounting it on the drivers side
Tue Mar 10, 2015 9:52 pm |
Tue Mar 10, 2015 9:53 pm |
sykanr0ng
On a stock Bronco the license plate mounts on the driver side.
To move it adds complication to mounting the bumper.
To block it from view is illegal.
Tue Mar 10, 2015 9:56 pm |
Ah ya, forgot about that nugget.. you could mount it somehow to the center of the tire i guess..
which brings up another question. why does the license plate holder flip up? My guess was if you had to drive with teh tailgate down you could flip up the license plate and have it showing when the gate was down.
Tue Mar 10, 2015 9:57 pm |
rooster
That's a good theory, I bet your right. I decided to take mine off and weld in all the holes when I painted my bronco so I'm not really worried about where to mount the license plate
Tue Mar 10, 2015 10:04 pm |
Tue Mar 10, 2015 10:10 pm |
rooster
Thanks! That should be just what I need. What size square tubing did you use on yours?
Tue Mar 10, 2015 10:13 pm |
Tue Mar 10, 2015 10:15 pm |
rooster
Ok cool thanks man
Tue Mar 10, 2015 10:16 pm |
Ruff stuff has another good option: http://www.ruffstuffspecialties.com/catalog/STIRES.htmlIt's what I used when mine got done. It's essentially the same thing without the tire plate if you can make that yourself. There is a BRONCO discount code for 10% off as well.
Tue Mar 10, 2015 10:50 pm |
I just ran across what could possibly be a cheap alternative to building a hinge if you can find the tube cheap in someones scrap pile. It's 2" and 1.5" x .25 DOM sleeved together: Then capped with a huge bolt and nylon washer: I think the critical thing when building these is to keep them from bouncing. Metal fatigue causes the shank to shear off and now you'd got 100+lbs of tire and steel bouncing down the highway... I used Delrin plastic to carry the weight when it's closed.
Wed Mar 11, 2015 2:33 am |
Wed Mar 11, 2015 6:26 am |
Wed Mar 11, 2015 6:27 am |
Sorry for the double hijack. I have removed my tire carrier as it was using a spindle and bent about to fail. Changing it to double sheer, rebuilding the mount and adding derlin rests to help with the bounce and weight.
Depending on where you live I would check local fabricators they usually have the parts precut and save you on shipping.
Wed Mar 11, 2015 6:57 am |
rooster
Thanks for all the great info guys!
Wed Mar 11, 2015 7:14 am |
BNC04
Mine is on the drivers side. Justin and Kirk did the fab and paint, I did the design and cheering:) You can see the section of 2 inch receiver hitch that is added to the plate for the tire. My plan is to build a license plate bracket and integrate a mount for a LED light for a backup, rear flood light. Right now, I have the plate zip tied to the rim of the spare tire. The license plate can move from the bumper receiver to the receiver in the tire carrier as needed. Brett
Wed Mar 11, 2015 7:55 am |
Wed Mar 11, 2015 9:05 am |
rooster
Bnco4. That looks bada**. Thanks for the pictures! What size tubing is that?
Wed Mar 11, 2015 12:43 pm |
BNC04
Wed Mar 11, 2015 1:55 pm |
rooster
That looks sweet!
Wed Mar 11, 2015 4:11 pm |
The 2x5 is 1/4". I don't remember what the 2x2 is.
Wed Mar 11, 2015 4:26 pm |
I thought the 2x5 was 3/16, I'm too old to remember. I think i matched the thickness what ever it was.
Wed Mar 11, 2015 5:39 pm |
It's 1/4. I've got a chunk of it out in the garage.
Wed Mar 11, 2015 6:41 pm |
BNC04
Wed Mar 11, 2015 6:58 pm |
