It is currently Tue Oct 01, 2024 8:31 pm
9" rebuild tech day?
Here's a placeholder and feeler for a tech day. The 9" in Stroppe'd is starting to make stranger sounds. It's always made some noise. Now it's becoming troublesome. So, it's time for a rebuild.
I can host said event at my place in Colorado Springs. We could do some sort of portable, hand held breakfast nourishment.
The catch is I've never rebuilt a 9 and would be looking for a subject matter expert to lead the work.
Anyone interested in leading? Anyone interested in participating?
March is packed full for me. April is looking quite promising.
Wed Mar 11, 2015 9:47 am |
Dukietown
Re: 9
Interested. I'd like to rebuild mine at some point or at least know how to inspect mine to see if it needs rebuilt.
Wed Mar 11, 2015 9:53 am |
Re: 9
I am interested as that is high on my to do list as well.
Wed Mar 11, 2015 9:57 am |
Re: 9
I'd come just for the handheld breakfast nourishment.
Wed Mar 11, 2015 10:03 am |
Re: 9" rebuild tech day?
Mmmmm bfast
Wed Mar 11, 2015 2:54 pm |
I don't know how long the rebuild process takes, but I was thinking this could be a max participation event. Maybe get 2-3 axles together and have groups working on each while one overlord, er, instructor talks us through the process while a large drum is pounded in the background.
Perhaps we can get someone to chime in on what all needs to be purchased to make this happen. I'd like to rebuild everything on my axle, minus the brakes. And I'm certain I will be purchasing new gears.
Wed Mar 11, 2015 4:11 pm |
2-3 no way, 1-2 maybe, 1 for sure. Especially if it's a complete rebuild. Stock rebuild or? I can post up what you need.
Wed Mar 11, 2015 4:23 pm |
Re: 9
You'd need a rebuild kit, gears if you're doing them, and wheel bearings. It'd be worth dropping the center section to verify what size carrier bearings you've got. Mine are larger than stock and it caused some consternation and a parts run.
Wed Mar 11, 2015 4:24 pm |
horseplay
Re: 9
Tools to consider torque Wrench, dial indicator & magnetic stand ,spanner Wrench for pre-load ,slide hammer with hub adapter if the axles haven't been out before. Maybe a extra crush sleeve just in case. A torque multiplier is nice for setting the crush sleeve.
Wed Mar 11, 2015 7:47 pm |
Wed Mar 11, 2015 7:53 pm |
I've got all the tools necessary for the rebuild. Are you going to rebuild the trac lock?
Wed Mar 11, 2015 8:11 pm |
Re: 9
Wed Mar 11, 2015 8:49 pm |
Wed Mar 11, 2015 9:20 pm |
Re: 9
They can be found in 28 spline flavor too. '76-'77 Broncos had the 4-pinion.
Wed Mar 11, 2015 9:43 pm |
Re: 9
Dont waste your time with a regular crush sleeve. Buy the shimmable pack that replaces the crush sleeve. Under hard use and acceleration the crush sleeves can collapse.
Thu Mar 12, 2015 6:12 am |
Dirtheadz
Re: 9
Thu Mar 12, 2015 7:11 am |
Re: 9
Depends on who attends. If we get several folks that know how to do it, then 3-4 is doable. Doing the 9" and D44 on my rig to most of an afternoon with Kinder, Crawlercreations, and Viper present.
Thu Mar 12, 2015 8:50 am |
Unaweep
Re: 9
I'd love to attend this, I would combine it with a work trip if the date works out.
I never worked on any differentials before, although I destroyed a couple of them :)
Erik
Mon Mar 16, 2015 6:50 pm |
Freewheeler
Joined: Fri Mar 13, 2015 3:30 pm Posts: 32 Location: Westminster, CO
Re: 9
I'd love to attend as well, since I plan on replacing my 3.50 Trac-Loc with a Detroit and different gears in the near-ish future.
_________________ 1978 Bronco w/Free Wheeling Package - all original from factory: 400/C6/NP205, 9" rear/high pinion D44, not to mention the tri-color stripes and plaid seats. WH 4” lift, 35’s, WH Hydroboost, rear disc kit, chrome shafts, 4.11’s, Detroit’s f/r, 3G alt, Protofab cage and rear bumper, restored interior and other stuff.
Mon Mar 16, 2015 8:59 pm |
Re: 9
The 9in is the easiest to set-up for sure. No need to press anything apart to change shim packs.
Tue Mar 17, 2015 6:15 am |
av8nmech
Joined: Wed May 28, 2014 7:22 am Posts: 14 Images: 0 Location: Aurora
Re: 9
I'm in, I'll pull my carrier out this weekend to figure out what size bearings I need. Where's the best place you guys have found to get a rebuild kit?
Can we get Chorizo buritos? Those are the best.
Thu Mar 26, 2015 8:19 am |
Thu Mar 26, 2015 10:42 am |
Most kits are good quality, I've used G2 from 4wheelparts, Yukon & USA standard gear.
Thu Mar 26, 2015 2:26 pm |
Re: 9
Thu Mar 26, 2015 5:15 pm |
Benwehmann
Joined: Fri Mar 27, 2015 11:53 pm Posts: 1 Location: Denver, CO
Re: 9
I just moved to Denver about 6 months ago and just found this group. I have a 1973 Bronco but it is still in Wisconsin in my storage unit. I have never rebuilt a 9" but would love to come if you are still going to make this happen.
Sat Mar 28, 2015 9:32 am |
Sat Mar 28, 2015 10:28 am |
I'll be looking to do this soon. Anyone interested in reviving this thread, leading this tech build day?
Mon Sep 07, 2015 8:39 pm |
colby45
Re: 9
I'd be interested in participating to learn the process, but I have never done a rebuild before.
Tue Sep 08, 2015 2:14 pm |
Re: 9
The last one we did was up in Greeley at Addicted Offroad and it was pretty awesome! I would be very interested in attending another
Wed Sep 09, 2015 2:04 pm |
sykanr0ng
Re: 9
Wed Sep 09, 2015 3:19 pm |
