www.ColoradoClassicBroncos.com - View topic - "Cope cut" layout in large diameter pipe
It is currently Tue Nov 05, 2024 9:22 pm
Reply to topic  [ 5 posts ]
Post "Cope cut" layout in large diameter pipe
Anybody have short cuts on layout and cutting a 90 degree cope/saddle cut in a 20" diameter .250 wall pipe?
I have the cutting tools, just need layout advice.
Thanks.
Wed Apr 08, 2015 7:26 pm
Post Re: "Cope cut" layout in large diameter pipe
Cut out a 20" circle on poster board ,lay that down and trace it.
Wed Apr 08, 2015 9:19 pm
I thought their used to be a formula for large pipe, something like 1/4 of the diameter. Hell... I really did drop out & become a statistic, when I thought I wanted to be a mechanical engineer.
Thu Apr 09, 2015 2:37 pm
Here is a formua:
X = (R1/Sin (JA)) - (((R1 - Sqr(R1^2-(Cos ( AP ) * R2)^2)) / Sin(JA)) + ((Tan (90 - JA) * (Sin(AP) * R2))))
R1 = large radius
R2 = small radius
JA = Joint Angle
AP = AnglePosition
I also found a method of laying out a pattern.
Thu Apr 09, 2015 4:31 pm
You can purchase paper templates at your welding store, they aren't expensive and will last a lifetime and work on many sizes of tube/pipe and various degrees/angles.
Erik
Sun Apr 12, 2015 8:40 am
32,793,793 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
