Register •
FAQ
• Login
It is currently Fri Nov 01, 2024 5:36 am
[ 5 posts ] |
3 speed clutch linkage clearance
Rockhorse
Joined: Mon Nov 15, 2010 4:45 pm Posts: 6 Location: Lakewood
I have a 69 with a 351 and full length headers and a 3 speed. i am having clutch linkage clearance issues. The linkage rubs on the header, and I can't get it into position. Can I bend the linkage? Or am I sol and have the reason to go all nv 4550 up in here! I am a long time lurker but This is my virgin post on CCB so be gentle
Mon Apr 13, 2015 10:49 pm |
Re: 3 speed clutch linkage clearance
Welcome! You'll find us deeply enabling. The only possible solution is a better transmission.
What part of the linkage is rubbing?
Mon Apr 13, 2015 11:38 pm |
Rockhorse
The fork push rod where it connects to the equalizer bar.
Tue Apr 14, 2015 8:38 am |
Very common interference spot for long tube headers, especially with a 351. If you can bend the linkage left or right you should have no adjustment problems. If you need to change the fore or aft position then you'll need to adjust the rod length beyond the factory amount.
Tue Apr 14, 2015 2:47 pm |
Rockhorse
Thank you kind Sirs! Will give it a go this weekend.
Tue Apr 14, 2015 10:23 pm |
[ 5 posts ] |
