It is currently Fri Oct 04, 2024 7:30 pm
[ 6 posts ] |
Who's looking to go full width?
77 ford f-250 axles- $200.00 for both!
Note: the seller claims the front is also a Dana 60. Unless someone swapped a Dana 60 in later, it should be a Dana 44 HD with dual piston calipers. Only other way it might be a Dana 60 is if it was a Snow Fighter model, and I think those were F350s, not 250s.
Mon Jan 24, 2011 2:50 pm |
Re: Who's looking to go full width?
Flat top knuckles too!
Mon Jan 24, 2011 5:05 pm |
Mon Jan 24, 2011 6:07 pm |
If I had kept the 66 I planned to go full width with the axles from the Blue Bomber, my old 77 F250.
Flat top knuckles indeed. 200 seems pretty darn cheap to me.
Mon Jan 24, 2011 6:18 pm |
Colorado75bronc
so you know zack some of the higher gvw f-250's had d60 fronts, and the snow fighter f-350's did too, my dad actually has a really sweet 79' snowfighter
Thu Mar 03, 2011 9:18 pm |
It's been deleted. That was a good deal assuming everything was in good shape.
Thu Mar 03, 2011 10:28 pm |
[ 6 posts ] |
