www.ColoradoClassicBroncos.com - View topic - Aluminum fabricators
It is currently Wed Nov 06, 2024 5:19 am
Reply to topic  [ 13 posts ]
Post Aluminum fabricators
Anyone have a good referral for a aluminum fabricator around town? I'm having interference problems with the fan/shroud thanks to my 1" body lift and need some fabrication done to basically move the opening down 1".
Mon Apr 20, 2015 1:33 pm
Post Re: Aluminum fabricators
can you just cut the bottom to clear? Most shrouds only cover half the fan anyways. Just my $.02
Mon Apr 20, 2015 2:51 pm
Mon Apr 20, 2015 3:02 pm
Option 4- move the radiator mounts down an inch to make up for the 1" BL.
Mon Apr 20, 2015 3:03 pm
If you want something fabed out of aluminum call this guy.Mike at Black Top Hobbies.303-941-1428
No b.s.this guy reasonable and top notch.
Mon Apr 20, 2015 4:11 pm
Probably cleanest to move our mounts on the shroud. I'd lean that way too. Let us know what you end up with.
Mon Apr 20, 2015 11:34 pm
Tue Apr 21, 2015 8:17 am
I moved the radiator mounts on mine which lowered both the radiator and fan shroud so there wasn't any fab needed to the actual shroud. Let me know if you need some help and would like to use my welder. I can probably squeeze some time in Friday or Saturday.
Tue Apr 21, 2015 8:24 am
Mike @Black Top Hobbies is a hellava fabricator.He works after hours so this might work out better for you if you have a 9to 5.Dose some awesome cages and chassis work for the drag race crowd.
Tue Apr 21, 2015 9:22 am
Tue Apr 21, 2015 10:39 am
I added two aluminum strips top and bottom on mine to lower the fan shroud on my 76. Machine bolts holding it together. No way I was going to cut the original mounts. However I'm using the original shroud with the hybrid aluminum extension and not an all new shroud.
If I had an all aluminum shroud I would have the extensions tig welded.
Tue Apr 21, 2015 10:43 am
Tue Apr 21, 2015 11:51 am
Tough to see in these pics..
Tue Apr 21, 2015 1:25 pm
32,796,419 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
