akaFrankCastle wrote:The pilot bushing is pressed in to the back of the crank. Pulling the flywheel (or pressure plate, in this case) won't get you any closer to getting that bushing out. What I did for mine, after reading up on it, was to pack the center of the bushing with axle grease until I couldn't get any more in. Then I took a dowel rod, inserted it in to the center of the bushing, and kept whacking the crap out of it until the bushing popped out.
hockeydad4-22 wrote:Same process except we used soft wax. The wax we use here to lubricate screws before we run them into the anchors. Worked great and no mess, just wipes off
Viperwolf1 wrote:Should be 164 tooth.
