It is currently Wed Nov 13, 2024 12:39 am
Now: The Old School Super Duty
Re: Now: The Old School Super Duty
I've seen the last one. Too complete for my tastes.
I'm looking for something in the sub-2k arena. Engine is immaterial as is the transmission. Axles are somewhat immaterial. If I go 7.3, I'll use a donor truck's D60/10.5 with rear disks and speed sensors. If I go 12V Cummins or similar, I will likely keep the stock axles for a bit.
Basic criteria is decent cab, matching VIN on cab and frame, TITLE, long bed frame. Original paint and a decent bed would be nice. Also, would like a camper special bed with the tool box built in.
The Idaho truck is off the table. The body is absolutely trashed with rust. And there are title issues (body swap, original VIN tag not saved). And the guy selling is not the titled owner (selling for "customer" who didn't like quote for repairs).
Tue Apr 28, 2015 12:31 pm |
what a pretty green $2999
Tue Apr 28, 2015 3:20 pm |
1978 Ford Supercab Ranger XLT F250 4x4 - $3250
Tue Apr 28, 2015 3:22 pm |
1974 Ford F250 Ranger SuperCab - $5000
Tue Apr 28, 2015 3:24 pm |
Maybe get some pics, its cheap!
75 f250 supercab ranger - $1500 (Tijeras)
Tue Apr 28, 2015 3:26 pm |
This one looks really nice and has the built in tool box. However looks like the picture is from 5 years ago... 1975 Ford Supercab - $3000
Tue Apr 28, 2015 3:28 pm |
I like this one... 1975 Ford F-150 - $4300
Tue Apr 28, 2015 3:34 pm |
#1: 2wd #2: I see a high rust to price ratio. #3: 2wd AND more than I want to spend #4: 73-77.5 frames are more narrow than later frames making the 7.3 swap a larger pain in the ass. #5: F150
Tue Apr 28, 2015 3:36 pm |
1976 f150 supercab - $2700
Tue Apr 28, 2015 3:37 pm |
Is this my payback for all of the submission to the "unique daily driver" thread?
Tue Apr 28, 2015 3:38 pm |
Tue Apr 28, 2015 3:46 pm |
It's an F150. I'd prefer F250-350. I do believe there is a frame difference.
Tue Apr 28, 2015 4:11 pm |
sykanr0ng
As far as I know the front frame width is the same in all years of the dentside Ford. It was the width of the back of the frame that changed with the highboy F250 being the last hold-out until mid 1977 model year. A good source of info: http://www.fordification.net/
Tue Apr 28, 2015 7:39 pm |
Tue Apr 28, 2015 11:24 pm |
sykanr0ng
Here is a chart of frame widths and wheel bases for some of the F series trucks, covers 1960-1979, (accuracy?):
Wed Apr 29, 2015 1:07 am |
I will be more diligent and detail oriented in my search.
Wed Apr 29, 2015 7:40 am |
I appreciate that.
What sucks is I like the subtle body styling differences in the 73-77 trucks but would prefer the rolling chassis from a 77.5-79. The extended cabs were only 2WD F100-150 in 73-77.5. Also, because diesel has the larger spout I'm almost completely stuck with a 77.5-79 bed, in order to accommodate the installation of the larger fill necks without incurring body work.
Wed Apr 29, 2015 8:03 am |
these things are hard to find.. and the ones that are found are asking quite a bit for crap. I know... short bed pfft '79 Ford F250 Crew Cab 4x4 $5000 obo http://lascruces.craigslist.org/cto/4973892202.html
Wed Apr 29, 2015 10:26 pm |
Wed Apr 29, 2015 10:34 pm |
Seen the STL one last week. Knowing MDOT's history of salt use, I'm sure that thing is just a shell.
About 4 years ago I found a CCSB in Pueblo for 1200. It was in great shape and RAN. Called the guy, set up a time, grabbed my buddy's trailer and headed down. Made a follow up call just to be sure and the seller told me a guy had just drove it off.
Wed Apr 29, 2015 10:52 pm |
sykanr0ng
Last year these trucks were all over now they have vanished Not a SuperCab but '74 F250 4x4 7.3 diesel and auto come with it (not installed): http://denver.craigslist.org/cto/4971455365.html
Wed Apr 29, 2015 10:55 pm |
can't tell if this is a 4x4 or not... 1978 f350 460 - $800 http://albuquerque.craigslist.org/cto/4988192545.html
Wed Apr 29, 2015 10:59 pm |
2WD. You can just barely see the rear mounted PS gear box in the last picture.
Wed Apr 29, 2015 11:15 pm |
The one in Las Cruces isn't bad. That doesn't appear to be a "short bed" in today's terms...
Thu Apr 30, 2015 1:34 am |
TOOLMAN
I concur. That crew cab in Las Cruces is sweet. Plus, super hard to find those!
Thu Apr 30, 2015 7:29 am |
Found a cab today at the salvage yard. Has been repainted once. Didn't see any rust on it at all. Original vinyl floor liner and back seat still in it. Just might have to go back and grab it for a later date.
Fri May 01, 2015 9:20 pm |
sykanr0ng
Fri May 01, 2015 10:57 pm |
Wish I knew someone close to here who could check this one out for me. http://goldcountry.craigslist.org/cto/5005576430.html
Sat May 02, 2015 9:15 pm |
Let me know if you decide it's worth checking out. It's about 1 1/2 hrs from me.
Sat May 02, 2015 10:45 pm |
Sat May 02, 2015 11:14 pm |
