www.ColoradoClassicBroncos.com - View topic - Dana 44 ball joint adjustment
It is currently Sun Oct 06, 2024 7:16 pm
Reply to topic  [ 9 posts ]
Post Dana 44 ball joint adjustment
I'm starting to get the sense that my front axle had a difficult life prior to my buying it. I've got the passenger's side knuckle installed and tightened to spec (40 ft/lbs). To get it there, I had to cinch the adjusting sleeve down fairly low, and now have a couple of threads of it showing out of the bottom of the upper C. How big a deal is this? I suspect it could affect camber a little, but is there anything else I should be concerned about if I'm able to get it to align correctly?
Sat May 02, 2015 5:38 pm
Post Re: Dana 44 ball joint adjustment
I don't think that's uncommon, I've seen at least one or two setup that way. You'll know after the alignment if you have bigger problems.
Sat May 02, 2015 6:11 pm
You've got the spindle shims. ;)
I also have the threads showing on the drivers side Ian a little over a degree off on camber.
Sat May 02, 2015 10:31 pm
Thanks guys! I'm not too worried about the alignment from this issue, just wasn't sure if it was normal/common/safe. We'll see how it looks after I get everything back together and take it for an alignment.
Sun May 03, 2015 12:04 am
Mines the same way.
Mon May 04, 2015 6:12 am
It should be okay and not affect alignment. If more than 25% of the threads are sticking out the bottom, then I would be a little concerned. Are you planning to align it to factory specs or modern specs?
Mon May 04, 2015 11:07 am
I'm poem to input on that. My preference is usually to update stuff to modern standards.
Mon May 04, 2015 11:41 am
Haha, Right answer.
I dropped some adjustable sleeves on mine. I plan to run 0.00-0.25 degrees camber, 0.00-0.25 degrees toe, and 4-6 degrees of caster. It should handle and wear tires a little better.
We can talk when you are getting closer to alignment time.
Mon May 04, 2015 7:21 pm
Thanks, I'll take you up on that.
Mon May 04, 2015 8:37 pm
32,477,582 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
