www.ColoradoClassicBroncos.com - View topic - rear axle bearings
It is currently Sat Sep 28, 2024 4:37 pm
Reply to topic  [ 16 posts ]
 rear axle bearings
Post rear axle bearings
Had a mishap on my way to the breakfast.
So my question is whats a better option. WH offers 2 styles. Ball bearing or tapered bearing. which would you do and why?
Sat Apr 18, 2015 2:56 pm
Post Re: rear axle bearings
The tapered bearings are stronger. But you need to change to the external seal which can leak.
Sat Apr 18, 2015 3:51 pm
Found out that the tapered bearings WH sell will not fit factory axles. Only for the aftermarket HD shafts. So that answers that for me too.
Sat Apr 18, 2015 4:00 pm
Phil, correct me if I'm wrong, but only the big bearing housings can run the factory sized tapered bearings, correct?
Sat Apr 18, 2015 8:34 pm
I had a 74-75 medium bearing axle with a taper bearing. I think it's made for all of them but only for after market axles
Sat Apr 18, 2015 8:48 pm
Sat Apr 18, 2015 9:05 pm
Sat Apr 18, 2015 10:05 pm
Im gonna go through the whole thing. I do have a fear the axle is toast.
Sat Apr 18, 2015 11:17 pm
31 splines are calling.
Sat Apr 18, 2015 11:36 pm
They are but dont have the funds for a 31spline arb.
Sun Apr 19, 2015 8:00 am
I did find out some info the past few days. For the last 39 years this bronco has been in the family the bearings have never been replaced. So 41yrs old and 162k miles with lots and lots of wheelin.
Sun Apr 26, 2015 1:25 pm
And he found the passenger side to be bad as well. Now to get them replaced and ready to go for the summer wheeling season.
Sat May 23, 2015 7:08 pm
Ok got the axle apart this weekend. This is what I found. The drivers side bearing fell apart when I tried to press it off. The bearing surface on the shaft looks good. Splines are a little twisted. Im gonna slap new bearings on it and go for now. No point in spending money on new shafts when I want to go 31 spline soon. The centering hole in the spring perch is ovaled out too. So i'll be adding WH big perches.
Tue May 26, 2015 6:46 am
From what the axle experts say spline twist is actually normal and expected, needs to go to about a spline off before replacement.
Absorbing shock is better than shattering from it.
Tue May 26, 2015 8:45 am
Tue May 26, 2015 5:30 pm
Tue May 26, 2015 6:23 pm
32,366,110 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
