Register •
FAQ
• Login
It is currently Wed Jun 26, 2024 4:28 am
[ 4 posts ] |
TOOLMAN
![Post Post](./styles/acidtech/imageset/icon_topic_latest.gif) EFI Spark Plug Gap
I finished up my EFI conversion and while EFIGuy was tuning my motor, he mentioned I should probably replace the plugs. So, here's the question: Do I gap the new plugs based on the original 302 (.028-.032) because I'm running a mid-70s long block, or to an Explorer 5.0 (.054). My guess would be .054 because I'm running the coil packs. Is this a correct assumption? Just thought I would run it by some more knowledgeable people before I install them. There's quite a big discrepancy there!
Tue May 26, 2015 12:36 pm |
sykanr0ng
![Post Post](./styles/acidtech/imageset/icon_topic_latest.gif) Re: EFI Spark Plug Gap
Modern ignition = modern sparkplug gap.
Those coil packs are putting out the same energy in your Bronco as they were in the Explorer.
Tue May 26, 2015 12:54 pm |
You want to run as much as possible before you get spark blow out.
Tue May 26, 2015 8:00 pm |
TOOLMAN
So, for the record, I did .054 and it seems to work just fine. I had a tiny miss and this seemed to cure it. The old plugs were about a year old and looked pretty good, but were gapped at probably .032-.035. Note: I'm using stock Motorcraft coil packs.
Wed May 27, 2015 7:07 am |
[ 4 posts ] |
