www.ColoradoClassicBroncos.com - View topic - Fuel Pump
It is currently Sat Nov 02, 2024 4:35 am
Reply to topic  [ 16 posts ]
 Fuel Pump
Post Fuel Pump
Looking for recommendations. External Fuel pump for EFI. who has what and, what are your likes - dislikes? (I'm running an explorer 5.0)
Mon Jun 08, 2015 8:09 am
Post Re: Fuel Pump
Carter P4070 low pressure pump
Airtex E2000 high pressure pump (cross reference as late 80's truck/Bronco EFI pump)
LP pump has been in only 1 year. I swapped it due to Viperwolf's warning about the LP pump I was running. HP pump has been in 3 years.
Mon Jun 08, 2015 12:17 pm
Post Re: Fuel Pump
I like simplicity. I believe on Shawn Gregg's we just put an e2000 pump close to the tank (low as you can get it). I don't think he has had any problems with it. That's what I would try first. If you have problems then you can invest in a more complicated system.
Mon Jun 08, 2015 12:59 pm
Post Re: Fuel Pump
Cool I see Advance has them in stock. Thanks!
Mon Jun 08, 2015 6:52 pm
Post Re: Fuel Pump
Mon Jun 08, 2015 7:11 pm
Post Re: Fuel Pump
I originally installed a frame mounted fuel pump on my EFI install but it wouldn't pull enough fuel pressure to run my engine. I then went to an internal tank fuel pump, it has been running flawlessly ever since. I'm not sure the difference but my experience is but the internal pump has performed better than I expected.
Mon Jun 08, 2015 8:48 pm
Post Re: Fuel Pump
Mon Jun 08, 2015 9:36 pm
Post Re: Fuel Pump
An in tank pump would be my preference if I had the tank for it. not ready to part with the $$ just yet.
Tue Jun 09, 2015 12:15 am
Post Re: Fuel Pump
I'm running a Holley Red LP at the tank, and the factory external HP pump from the donor truck (1994 F-250). The red pump makes a bit of noise and it may fail at some point, but it's been that way for 6 years.
No accumulator on mine.
Tue Jun 09, 2015 1:18 am
Post Re: Fuel Pump
Tue Jun 09, 2015 9:30 am
Post Re: Fuel Pump
Wed Jun 10, 2015 12:28 am
Images: 1
Post Re: Fuel Pump
I modified fuel tank . Cut 3 inch off top and welded back together also cut hole in top and made baffles in tank for pump . All is well so far , bottom line I have extra inline pump that came with msd injection kit if you are still lookin for pump . Cheers
Mon Jul 06, 2015 11:40 pm
Post Re: Fuel Pump
Old thread sorry, but I know my Holley LP pressure is likely done. So is this Carter pump still the go to? It's half the price the Holley is, and only slightly larger.
Wed Aug 17, 2016 12:21 pm
Post Re: Fuel Pump
Wed Aug 17, 2016 1:49 pm
Post Re: Fuel Pump
I went with the e2000 pump. some time down the road I will likely go with an in tank pump.
Wed Aug 17, 2016 8:19 pm
Post Re: Fuel Pump
Good news Eck!
John - I have the factory HP fuel pump located inside the engine bay. It's less work for me to replace LP pump than to move the HP pump. The downside to that is if the LP pump fails again, the engine cuts out if I try to add any throttle, but at least it still runs... Perhaps I should spend $30+/- and rebuild the Holley as a spare...
Thu Aug 18, 2016 7:25 am
32,752,804 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
