It is currently Sun Oct 06, 2024 6:30 am
[ 9 posts ] |
Ball joints
What's the general consensus on the good stuff? I'm going to be in the drive all day with the super duty. Would prefer to replace once.
Thu Jun 25, 2015 9:42 pm |
Re: Ball joints
Spicer or the good Moog. Napa sells Spicer as their own Napa Gold.
Thu Jun 25, 2015 11:03 pm |
Re: Ball joints
Spicer.
Moog is fine so long as you stay away from the "problem solver" series. They tend to oversize the ball joint housings and it stretches the hole in the axle. We get calls on these all the time at work because people try to replace these with something OE sized and it fall through the hole.
Fri Jun 26, 2015 9:00 am |
Re: Ball joints
Another vote for Spicer.
Fri Jun 26, 2015 10:25 am |
Re: Ball joints
Fri Jun 26, 2015 11:56 am |
Re: Ball joints
Sat Jun 27, 2015 12:25 am |
Re: Ball joints
Thanks, it was my F250, hopefully you are right.
Sat Jun 27, 2015 8:27 am |
Re: Ball joints
Mon Jun 29, 2015 11:52 am |
Colorado75bronc
Re: Ball joints
Spicer.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Mon Jul 20, 2015 11:00 pm |
[ 9 posts ] |
