www.ColoradoClassicBroncos.com - View topic - EFI harness power wiring question.....I have no brown plug!?
It is currently Wed Nov 06, 2024 5:44 pm
Reply to topic  [ 2 posts ]
Images: 5
Post EFI harness power wiring question.....I have no brown plug!?
First off I would like to thank casadejohnson for stopping by to help with his bronco.
I am in the middle (towards the end) of an EFI swap. I swapped everything from an 89 Grand Marquis. I had the engine, all sensors, full harness all the way to the starter solenoid.
I have everything installed. I kept the EGR parts, but got rid of the TAD and TAB and the vacuum lines. I have all the sensors wired. I am using the start hot from the original harness. I am working on the fural system.
The problem.....I have no idea where to power the harness with the run and run/start wires. I have several books and just ordered another. I have no BROWN connector #31. I do have a grey conector withthe same configuration and tabs, plus a black withthe same configuration, but different tabs.
The Grey only has 5 of the 8 pins used, the black has all 8 wires. Neither has the same colored wires referenced for the brown connector. I have found other forums on the web with this issue, but none with answers. The GREY connector is near the area where the harness has the computer, there is also o block out? pin right near it. The BLACK connector is about 1/3 way between the computer and the solenoids on the drivers side portion of the harness. There is also a rectangular 6 pin connector near it.
I have the factory Vacuum/electrical troubleshooting manual, but it does not have enough detail. I just ordered a copy of the main service manual with electrical diagrams so I hope that will help.
Any help is great. Anyone with an answer that is close has a cold beer waiting in my garage.
Thu Oct 21, 2010 8:14 pm
Post Re: EFI harness power wiring question.....I have no brown pl
Will be interesting to follow this thread - I have no clue what the heck you are talking about :) Sounds like you are trying to launch the Space Shuttle. Best of luck. Remember, always cut the red wire, then the blue wire.
Thu Oct 21, 2010 8:35 pm
32,800,749 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
