www.ColoradoClassicBroncos.com - View topic - Landshark's 72 Build
It is currently Thu Nov 21, 2024 6:20 pm
Reply to topic  [ 78 posts ]  Go to page 1, 2, 3  Next
Post Landshark's 72 Build
Well with the help of Rob (zoso) I finally went and picked up the 72 and brought it home. Just had one locked up drum brake and after a few good wacks we broke it up and pushed it to the garage.
Made in Janurary 1972, 302, three speed, Dana 44, drum brakes all around, manual steering, no idea on which 9 inch it has.
Cleaned it out a bit, removed the rat turds and disinfected it. Looks to be in decent shape, will eventually need a few panels replaced, including Inner kick panels, floors etc etc.. overall the wiring looks to be fairly unmolested with just a few additional wires here and there.
My short term plans are to initially to try and get it started (anyone want to help???) with the hopes of making it my run around for the time being but there are a few things I will have to replace or source to get it running and safe.
Long term its to be determined - i have some plans but it will be at least a year before I will even begin on it.
Anyway for now here are some photos.
Sun Aug 02, 2015 10:06 pm
Post Re: Landshark's 72 Build
Real solid start, looks like a fun project! ;) Congrats!
I'm jealous
Mon Aug 03, 2015 8:20 am
I think no matter what happens, no matter what you do to restore/modify etc... that headliner has to stay!
Mon Aug 03, 2015 8:23 am
Images: 2
That is a fantastic headliner. That's a great looking rig. Looks like a solid start for a project!
Sally
'66 Halfcab
Mon Aug 03, 2015 10:22 am
Great pictures.
Interesting hand brake.
Mon Aug 03, 2015 10:44 am
X3 on the head liner. keep things warm in the winter
Tue Aug 04, 2015 8:49 am
Top is coming off. I will raffle off the carpet :)
Tue Aug 04, 2015 9:16 am
That rig looks familiar but I can't recall where I've seen it (or pics of it)
Looks like a great starting point
Tue Aug 04, 2015 11:32 am
Nice! I would love to come give you a hand replacing body panels...I probably need to learn.
Tue Aug 04, 2015 12:31 pm
Tue Aug 04, 2015 2:22 pm
Tue Aug 04, 2015 2:23 pm
Tue Aug 04, 2015 5:08 pm
Tue Aug 04, 2015 8:18 pm
I got the engine to turn over. Then I put new oil in and filter on , new spark plugs, fuel filter, fuel hose to pump.
I think the only thing I'm missing is the coil?
Don't think the one from my 76 will work?
Anyone have one to use?
Tue Aug 04, 2015 8:22 pm
I should have one from my 74' engine. Pick it up when you get your seats.
Tue Aug 04, 2015 8:35 pm
Ok will do thanks.
Tue Aug 04, 2015 9:29 pm
Subscribed
Wed Aug 05, 2015 5:06 am
She's alive.
Too bad the cb doesn't work :(
Wed Aug 05, 2015 7:28 pm
I guess the coil worked.
Wed Aug 05, 2015 8:41 pm
It did indeed and I found my old wire stash.
Wed Aug 05, 2015 11:14 pm
Runs smooth! Looks like you're acquiring missing parts pretty quickly. I already see the missing fender hung.
Thu Aug 06, 2015 1:08 am
Thu Aug 06, 2015 8:44 am
Try Don for a radio. I have one but no faceplate and no idea if it works or not.
Thu Aug 06, 2015 8:51 am
I've got a few stock radios that work and are UN good shape.
Thu Aug 06, 2015 10:23 am
Thu Aug 06, 2015 11:37 am
Shears make short work of sheet metal.
Old metal and an impact make for broken shock mounts. I will probably weld a bolt end on for now.
By overwhelming request.
Thu Aug 06, 2015 9:45 pm
So plush, so much luxury! Nice work on the sheet metal! You don't waste any time do you?
Fri Aug 07, 2015 8:07 am
Fenders were really hacked. Also it gets two things out of my way and on the bronco.
So looks like I have a small bearing rear end. I need at least one drum for the rear. Anyone have one laying around? Hate to buy new when it will not be the long term rear end
Fri Aug 07, 2015 8:22 am
I still have my old drums that I replaced, you may be able to get them machined, I'm not sure. I opted to replace them when I was rebuilding the brakes to have all new. Is there a difference in the drums for small vs big? Let me know what you need to determine if they'll work for you.
Fri Aug 07, 2015 9:28 am
Fri Aug 07, 2015 4:39 pm
32,925,795 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
