351 collar
Re: 351 collar
Postby landshark » Sun Jul 20, 2014 7:08 pm
akaFrankCastle wrote:
akaFrankCastle wrote:I have for Corey, Landshark, and myself.
Chris, I can leave with Eck or Hockeydad. Have a preference?
Chris, yours is with Hockeydad.
Perfect will see him tomorrow
Re: 351 collar
Postby D&D72 » Sun Jul 20, 2014 7:45 pm
ZOSO wrote:Got any left? For that price I better pick one up.
got you covered Rob.
D&D72
Re: 351 collar
Postby hockeydad4-22 » Tue Jul 22, 2014 7:17 pm
Yup, sitting there in the cubby in the dash.
Re: 351 collar
Postby Eck » Wed Oct 08, 2014 4:25 pm
Has anyone else installed one of these yet? How did you put the retaining bolt in to keep the synchronizer put?
Also- with collar- only about 1/4inch of the oil pump shaft is engaged. EFIGuy gave me a part number for a longer shaft. I wasn't aware the shaft needed replacing so keep that in mind for anyone planning to do this in the future.
Re: 351 collar
Postby Moab Mike » Wed Oct 08, 2014 4:44 pm
That will need to be clocked correctly. The 5.0 is clocked parallel to the centerline of the engine. It also requires a special tool to hold the sensor in place when your installing it.
Moab Mike
Re: 351 collar
Postby Rox Crusher » Wed Oct 08, 2014 4:53 pm
That pink stuff wipes off (unless your trying to steal shawntell's motif)
Re: 351 collar
Postby EFI Guy » Wed Oct 08, 2014 5:10 pm
I've got ya covered on the tool to clock it correctly.
For the hold down ya gotta be creative. I've seen a longer bolt with washers welded together and ground for clearance, or two hold downs welded together like this:
http://classicbroncos.com/forums/showpost.php?p=2506645&postcount=106
EFI Guy
Re: 351 collar
Postby Eck » Wed Oct 08, 2014 5:27 pm
Yah- it's not installed yet- just test-firing it. I am thinking of painting it pink though.
Re: 351 collar
Postby EFI Guy » Wed Oct 08, 2014 7:55 pm
Bonus points if you can construct the hold down using nothing more than pink zip-ties.
EFI Guy
Re: 351 collar
Postby Eck » Wed Oct 08, 2014 8:50 pm
EFI Guy wrote:Bonus points if you can construct the hold down using nothing more than pink zip-ties.
Can I use JB Weld and/or bondo too?
Re: 351 collar
Postby D&D72 » Thu Oct 09, 2014 9:44 am
LMAO Eck. I may be able to scrounge some spacers that may work. Do you know what length is needed Garry?
D&D72
Re: 351 collar
Postby Eck » Thu Oct 09, 2014 7:17 pm
Any reason this wouldn't work?
Re: 351 collar
Postby Moab Mike » Thu Oct 09, 2014 7:59 pm
Eck wrote:Any reason this wouldn't work?
I would put a length of pipe on the bolt to support the washer. You could even braze or weld the pipe onto the washer so they're connected. The pipe should be slightly shorter than the bolt after it is tightened down.
Moab Mike
Re: 351 collar
Postby EFI Guy » Thu Oct 09, 2014 11:12 pm
D&D72 wrote:LMAO Eck. I may be able to scrounge some spacers that may work. Do you know what length is needed Garry?
.75" According to the drawing.
EFI Guy
Re: 351 collar
Postby Viperwolf1 » Tue Dec 16, 2014 1:31 am
I cut an extra groove for the hold down. I will add a few set screws to lock the collar to the synchro.
Re: 351 collar
Postby Kinder » Tue Dec 16, 2014 7:19 am
Very nice.
Re: 351 collar
Postby Justin » Tue Dec 16, 2014 9:20 am
Any chance more of these will get made?
Re: 351 collar
Postby hockeydad4-22 » Tue Dec 16, 2014 3:52 pm
Justin wrote:Any chance more of these will get made?
Yeah, what Justin said. I think I want 1 (ok 2) of them as well.
Re: 351 collar
Postby D&D72 » Tue Dec 16, 2014 5:28 pm
Yes I do have more in the works. I'll check with my buddy and get an update.
D&D72
Re: 351 collar
Postby Viperwolf1 » Tue Jan 20, 2015 10:52 pm
Here is my finished sensor.
Re: 351 collar
Postby akaFrankCastle » Wed Jan 21, 2015 12:15 am
Well played.
Re: 351 collar
Postby JGZ » Sun Oct 11, 2015 6:06 pm
Are these still available?
JGZ
Re: 351 collar
Postby Justin » Sun Oct 11, 2015 6:22 pm
x2!
Re: 351 collar
Postby D&D72 » Sun Oct 11, 2015 8:58 pm
I do have a few PM me a # and we can get arrangements made or meet up at ROX's in Nov.
D&D72
Re: 351 collar
Postby JGZ » Sun Oct 11, 2015 9:50 pm
PM sent
JGZ
Re: 351 collar
Postby Moab Mike » Thu Jan 14, 2016 1:20 pm
Any more of these available? Need one for my latest project.
Moab Mike
Re: 351 collar
Postby akaFrankCastle » Thu Jan 14, 2016 4:00 pm
Moab Mike wrote:Any more of these available? Need one for my latest project.
Got you covered.
Re: 351 collar
Postby Moab Mike » Thu Jan 14, 2016 6:16 pm
Got you covered.
Cool, thanks!
Moab Mike
Re: 351 collar
Postby akaFrankCastle » Fri Jan 15, 2016 3:36 pm
Got you covered.
Cool, thanks!
The location of the collar is secret. So secret that I don't know where it is. That being said, once I find it, I'll make sure it gets to you.
Re: 351 collar
Postby Moab Mike » Fri Jan 15, 2016 4:31 pm
Good deal, I'm in no hurry just wanted to make sure I wasn't out of luck.
Thanks again!
Moab Mike
