It is currently Fri Nov 01, 2024 4:42 am
[ 15 posts ] |
ZF5 adapter
This is a very long shot, but if anyone stumbles across a deal on a ZF5 to Dana 20 adapter please let me know. Thanks!
Mon Oct 12, 2015 8:53 am |
Re: ZF5 adapter
You know an Atlas doesn't require an adapter.
Mon Oct 12, 2015 12:12 pm |
Re: ZF5 adapter
I was curious to see who'd post that first. The thought has crossed my mind. I figure the adapter would be easy to sell if I go that route. I want to try the Dana first. They're pretty stout and I've got half a set of Tera low gears sitting on the shelf. The Dana is also a bunch lighter and I'm not sure I need the strength.
Mon Oct 12, 2015 12:36 pm |
Re: ZF5 adapter
Mon Oct 12, 2015 4:53 pm |
Re: ZF5 adapter
Mon Oct 12, 2015 5:03 pm |
Re: ZF5 adapter
I think Justin has more weight in link brackets welded to his front axle, than the difference between an Atlas & a D20. LOL.
Mon Oct 12, 2015 5:05 pm |
Re: ZF5 adapter
The fact that an Atlas didn't need an adapter was my excuse to spend more on a transfer case than I paid for my whole Bronco.
Mon Oct 12, 2015 5:06 pm |
Re: ZF5 adapter
Mon Oct 12, 2015 6:14 pm |
Re: ZF5 adapter
What's another 2 years wait to get the funding for an Atlas?
Mon Oct 12, 2015 6:16 pm |
Re: ZF5 adapter
(puts fingers in ears) LALALALALALALALALALALALALALALALALALALALALALALA!
Mon Oct 12, 2015 6:18 pm |
Re: ZF5 adapter
I bought an Atlas with no speedometer provision (saved almost 2" overall length). I already had an aftermarket speedometer that can use a GPS sensor. Since I went with the 4 speed, I really wanted to keep it all as short as possible. I also went with the smallest spacer that allows the ZF to bolt to the Atlas. They recommend a 1", I bought their smallest a .5". I could have used .25".
Mon Oct 12, 2015 6:39 pm |
Re: ZF5 adapter
What's the overall length of your atlas from mounting surface to the centerline of the u-joint? Their web site lists the length, but doesn't specify if that length includes the yoke. Mostly curious.
Mon Oct 12, 2015 6:48 pm |
Re: ZF5 adapter
16.75" case + .5" spacer
Mon Oct 12, 2015 6:56 pm |
ZF5 adapter
Don't forget the HD output shaft you will need for the Dana 20
Mon Oct 12, 2015 7:19 pm |
Re: ZF5 adapter
Thanks chad! I've heard mixed things on the Dana output. Lots of people seem to be running g the stock one without problems. I've got a spare and plan to carry that for now.
Mon Oct 12, 2015 7:25 pm |
[ 15 posts ] |
Users browsing this forum: No registered users and 83 guests |
