It is currently Fri Nov 01, 2024 9:35 am
[ 9 posts ] |
66 won't prime fuel pump
I can't get a new fuel pump here till Tuesday, so I thought I'd ask.
Is there anything I should know about the fuel pump on a 66 with a 170? Its a strange looking contraption.
It will run as long as I dump fuel down the carb, but the pump isn't pumping fuel. There is a clear, in line, fuel filter just before the carb, and its still empty, despite running the motor by hand for quite some time.
I'm guessing the old pump went bad after sitting for the last few years. But any advice is appreciated.
Sat Oct 17, 2015 2:14 pm |
Re: 66 won't prime fuel pump
The vacuum lines from the top of the pump are just connected together with a short section of vac hose. I looked at some pics, and that doesn't seem right. Where should they connect?
Sat Oct 17, 2015 2:54 pm |
To the manifold if I recall correctly. The '66 fuel pump is vacuum actuated.
Sat Oct 17, 2015 3:58 pm |
Give me a few minutes and I'll post up the fuel system pics from the '66 service manuals.
Sat Oct 17, 2015 3:59 pm |
Sat Oct 17, 2015 4:10 pm |
I'm confused. Is the fuel pump also a vac pump? Or is it vac actuated? The instructions above mention the fuel pump arm & a cam eccentric.
There is a plug in the side of the intake manifold, where the vac line should hook up. Also my vac wipers have been replaced with electric. So one side of the pump should be capped off?
Sat Oct 17, 2015 4:50 pm |
Yeah. It's confusing to me too. Seems as though it is a mechanical fuel/vacuum pump. Don't know where I got vacuum actuated from.
Sat Oct 17, 2015 8:52 pm |
I'm guessing the vacuum side of the pump adds extra vacuum to assist the wipers. Maybe engine vacuum couldn't keep up without some help.
If that is the case, it has nothing at all to do with why the pump won't prime.
Sat Oct 17, 2015 9:05 pm |
casadejohnson
The vacuum lines were for the vacuum driven wipers, which sucked bad. Buy a fuel pump for anything else with a 170 and it won't have the vacuum lines and will also be a lot less $,
Mon Oct 19, 2015 10:40 pm |
[ 9 posts ] |
