It is currently Fri Sep 20, 2024 11:44 pm
Got my horn working with some phone a friend help from Phil. It wouldn't be my usual weird situation if something unusual didn't happen. We figured out that I was missing the relay for the horn. I had also tested the horn to make sure it still worked. Drove the Bronco to NAPA and tested the relay and horn in the parking lot (it worked). Drive it home the 3 miles and pull into my garage and all of a sudden-- horn doesn't work. I can hear the relay working. So today I tested the horn again by hardwiring it to the battery. Somehow in the 3 mile drive home from NAPA, the horn become nonfunctional. So I went and bought a new horn and all seems to be good again. Now I can honk at stupid drivers with my new stupid horn.
Fri Oct 16, 2015 5:04 pm |
Turned her back into a "roller". Now it time to get back to work on everything else
Oh yeah, and I have to replace a spring on my big garage door, it decided to give up the ghost this morning. Thankfully my wife's car was outside.
Anyone have a recommendation for a garage door guy???
Sun Oct 18, 2015 3:38 pm |
JGZ
Anyone have a recommendation for a garage door guy???[/quote]
Give this guy a call.Zak Sutliff.303-960-6567.Tell him I sent you.Should be able to fix you up.
Sun Oct 18, 2015 3:49 pm |
DanHall
My wife drew up a CAD version of the bezel around the column for the dash to mate up with the new 2" tilt column. I'll try to get it printed soon and then see how my measurements work. Next design will be a collar for the firewall penetration so I can snug it up to the bracket. I'm thinking a simple sleeve will work here. I'll print in black ABS. If the bezel works I'll have to grab a Bronco logo and emboss it on the top and reprint. Should be sweet.
Sun Oct 18, 2015 8:52 pm |
TOOLMAN
Got pumpkin re-installed, and compressor/wiring/switches mostly connected up.
Mon Oct 19, 2015 10:29 am |
Thu Oct 22, 2015 3:35 pm |
JGZ
I'm happy he took good care of you.His dad and one of my best friends passed away in August and he was left to take over the business and take care of the family.A lot of responsibility for a 20 year old.He's also my daughter's boyfriend.Good kid.If anyone else needs garage door work hit him up.
Thu Oct 22, 2015 8:11 pm |
I'll add his contact info for future use, the last company that came out to the park for door work WON'T be getting a call back.
Fri Oct 23, 2015 8:40 am |
jre74
A bit of engine work today. It may not look different but it sure does run different!
EFI Guy strikes again!
Thanks again, Garry.
Sun Nov 01, 2015 5:35 pm |
DanHall
Pulled the Mountaineer into the garage and started tearing into it. Pulled the ECU which will have to head up to Garry pretty soon. Have a lot of work to go but it is nice to be on the "new" engine for a while. Will have to redo the harness but that is good work for a cold day, week, whatever. Hopefully I can have the Mountaineer out before we get any real snow so I can get the dd back in the garage.
Sun Nov 01, 2015 9:51 pm |
New points. New fuel pump. New fuel filter. New steel fuel line from pump to 6" short of carb inlet.
My WH Saginaw pump bracket is pissing me off. The threaded rod for the top of the bracket, that threads into the head, is either stripped or has stripped the head. I can't keep tension on the belt because of it.
Tore down a spare cluster, cleaned it up and swapped it into the truck, adjusted for the mileage on my Bronco. Nice to have a speedo again; even if it is 10mph off.
Tue Nov 03, 2015 12:10 am |
I have started the tear down. Got the t case pulled and mocked up on the 4r70w. Had to cut just under an inch off the output shaft. Modded the trans cross member for the new adapter.
Fri Nov 06, 2015 8:07 pm |
Fri Nov 06, 2015 8:34 pm |
Here's what I got
Fri Nov 06, 2015 8:44 pm |
Stopped by the yard and harvested a couple of side marker pigtails from the 70 Econo. I now have four working side markers.
Tue Dec 08, 2015 6:30 pm |
cravenbronco
I got a new 3 core aluminum radiator to replace the brass one that was in it.
Just another upgrade :-)
Fri Jan 22, 2016 4:21 pm |
cravenbronco
I'm getting ready to make a roll cage. I got all the steel that might be need plus extra. All that is needed is to extend the hoop and any extras such as a spare tire mount.
I will post more pics of the final outcome.
Wed Feb 17, 2016 5:19 pm |
Got the last parts for my Trans. Maybe next weekend ill tear it down.
Fri Feb 19, 2016 7:18 am |
Moab Mike
Fri Feb 19, 2016 8:18 am |
Fri Feb 19, 2016 6:09 pm |
rt9
Today , I installed a roll over vent to try and get rid of the dreaded Bronco burb when I remove the gas cap. Sent from my SM-G860P using Tapatalk
Sun May 15, 2016 1:32 pm |
Today I: - replaced the ZF fluid to RedLine MT 90 to try and quiet the loud gurgling at neutral idle. Unbelievably it completely cured it on first fire up. - thanks to BroncoRaider who is going to digital speedometer and gave me his speedo cable (mine was toast from my D20 problems in Moab). Installed that with a new gear that will hopefully get me closer to actual MPH. - re-bent my twin sticks. Found out while in Moab that they were interfering with the Trans shifter while in 4 low. I had a pretty tight window where they would fit between the shifter and my leg. - did the Cherokee wiper conversion. Messed up one of them as there is definitely an order to reattach everything. That spring is pretty stout and if you don't do it in a particular order, you definitely aren't getting it back on. Cost me $25 more than it should have but it's done!
Wed May 18, 2016 7:19 pm |
Wed Jun 15, 2016 8:51 pm |
Lookin great !
How did the upholstery on the arm rests turn out ?
Wed Jun 15, 2016 8:57 pm |
Turned out great. Material was expensive but now I have almost a yard for repairs or other projects. Only made this material one year (76) so not very common.
Thu Jun 16, 2016 8:19 am |
Finally got my cage painted and installed
Sun Jun 26, 2016 9:26 pm |
Sun Jun 26, 2016 9:36 pm |
Sorry, I was too busy scraping / scrubbing paint off my face and arms to take pics yesterday
The digital color matching was done a few years ago when we painted the engine bay during installation of 5.0. I don't know if the brand of paint we used this time made a difference but it is certainly a lot darker than what the body looks like. In the right light it almost looks black. Mismatched color aside, the paint job turned out pretty good considering who had the gun in his hands.
Mon Jun 27, 2016 6:07 pm |
Well, now you're gonna have to paint the rest of it. Looks nice. I wonder if the dark primer color affected it.
Mon Jun 27, 2016 6:38 pm |
Mon Jun 27, 2016 9:05 pm |
