It is currently Thu Oct 31, 2024 9:31 pm
[ 16 posts ] |
B.O.B.
Bad wheel bearing
On the way to work this morning and the right front wheel bearing gave out. My question is does it matter what bearings to use even though I have a Chevy disc swap. The rotors and hubs should all b from a bronco right? It's just the calipers and other stuff that is Chevy right?
Mon Oct 19, 2015 11:34 am |
TOOLMAN
Re: Bad wheel bearing
Yes. Timkin Sets 37 and 45. I can't remember which is the inner and which is the outer.
Mon Oct 19, 2015 11:55 am |
2x
Mon Oct 19, 2015 6:09 pm |
B.O.B.
Progress. So outer bearing went bye bye and welded islet to the spindle. Can't really tell if the hub/rotor got damaged as well. Going to need a parts list. Can everyone help. Still have 6 bolt knuckles. Do you think I should get new hub/rotor or is there a way to test to make sure it didn't get damaged as well? Thank you in advanced.
Tue Oct 20, 2015 3:09 pm |
In the hub, can you feel a groove? I would think that the outer race would have kept the hub in good shape.
Tue Oct 20, 2015 5:48 pm |
B.O.B.
Clean d up mostly everything and looks like hub is fine. Races took the blunt of my t and did their job. I do need a new spindle however and can't seem to find one in local parts store. Question is I can't remember but would it be the same spindle I had with my drum brakes? Anyone one have an extra lying around I can trade for a
Tue Oct 20, 2015 9:15 pm |
If you have the Chevy disc on there, you need a spindle from an early 70's Chevy 4x4. Typically pre-77. That will be the 6 bolt disc spindle.
Tue Oct 20, 2015 9:28 pm |
B.O.B.
I did some research and it looks like the Chevy swap has a seal pressed onto the axle. That's not my case . I might just have a 76-77 swap that uses the same spindle.
Wed Oct 21, 2015 6:05 am |
Not sure but I thought the 76-77 spindles were 5 bolt? I would do some research over on CB.com to verify. Do you have the spindle off? If so, maybe a picture could help us identify it.
Wed Oct 21, 2015 6:38 am |
TOOLMAN
Yes, Ford Dana 44 disc spindles were 5 hole and the Chevy/Waggy Dana 44 disc spindles are 6 hole. Not sure about a seal being pressed on...never heard of that. This happened to me a couple of years ago, but I had to cut the hub off to get it all apart. I think this is the spindle I bought (found a hub at the junkyard). The spindles are getting harder and harder to find at the junkyard.
Link to spindle:
I think they're made in India, but it was the cheapest I could find.
Wed Oct 21, 2015 7:19 am |
B.O.B.
Yes that's it. Really trying to find one local so I can get this thing back together. I am having to drive my Moms Jeep and it's making me upset. I got my kit from horsepower llc on eBay and that looks like the same one. Kind of interesting none of the parts stores carry them.
Wed Oct 21, 2015 9:41 am |
B.O.B.
Getting ready to put it back the tether and was wondering if there is a seal that goes over the spindle bearing before I bolt it back up. Been looking at some diagrams but do not see anything 100%.
Sun Nov 01, 2015 9:30 pm |
Sun Nov 01, 2015 11:18 pm |
B.O.B.
I saw that in the store by it looked to small. Maybe I'll have to take a better look.
Mon Nov 02, 2015 7:02 am |
B.O.B.
Does anybody have a exploded view on how everything gets put back together. I have a little seal I think that goes on with the spindle but don't really know where. That's pretty much it. The rest I know how to do it.
Tue Nov 03, 2015 7:49 pm |
This should get you close.
Tue Nov 03, 2015 9:10 pm |
[ 16 posts ] |
Users browsing this forum: No registered users and 9 guests |
