Re: What can I realistically expect from the 170?
Justin, I like how you upgraded GF to "hot". I'm pretty sure SO's don't allow that upgrade.
Tue Oct 13, 2015 4:26 pm |
Tue Oct 13, 2015 5:24 pm |
casadejohnson
Tue Oct 13, 2015 8:48 pm |
Wed Oct 14, 2015 2:13 am |
Wed Oct 14, 2015 7:39 am |
My wife likes to tell me about our kids closets after she reorganizes them. I usually look at her and say "you realize I'm humoring you, right?" This is probably why she won't let me have a hot girlfriend. Either that or it's the ever-evolving oil stains in the back of her minivan from hauling greasy truck parts.
Wed Oct 14, 2015 10:36 am |
TOOLMAN
I was kind of praying for this thread to die...but it has now resurrected itself and gotten pretty entertaining.
Let the ribaldry continue!!
Wed Oct 14, 2015 10:55 am |
colby45
Mon Oct 26, 2015 8:02 am |
Another bronco is cheaper. Sent from my iPhone using Tapatalk
Mon Oct 26, 2015 2:23 pm |
rt9
Mon Oct 26, 2015 7:30 pm |
BOBS 2 68S
A GF with a rust free running Bronco
Tue Oct 27, 2015 5:01 am |
There you go - just buy the current GF one for Christmas
Yeah - that will work, as long as there is some jewelry in the glove box....
Tue Oct 27, 2015 12:43 pm |
sykanr0ng
Tue Oct 27, 2015 10:36 pm |
colby45
A Bronco for her for Christmas would be the fastest way for me to become single again. Plus then I'd have 3 girlfriends needing my money, time and attention...
Wed Oct 28, 2015 7:36 am |
Wed Oct 28, 2015 3:24 pm |
And you could always sell one.
Wed Oct 28, 2015 4:08 pm |
colby45
Thu Oct 29, 2015 3:55 pm |
wholly side bar batman !
Thu Oct 29, 2015 4:03 pm |
Thu Oct 29, 2015 8:55 pm |
colby45
Well girlfriends and new mistresses (Broncos) aside. I'm finally going to do a compression test tomorrow and plug up the vacuum lines to see what's up with my 170. Then at least I'll know and I can plan to empty my wallet accordingly
Fri Oct 30, 2015 7:30 pm |
sykanr0ng
Fri Oct 30, 2015 8:07 pm |
colby45
Well plugging the vacuum lines did help, but it's still sluggish up hills. Here are the results of a compression test:
1 - 92 PSI 2 - 91 PSI 3 - 91 PSI 4 - 91 PSI 5 - 75 PSI :( 6 - 90 PSI
So I suppose one cylinder with low compression is probably not helping. I also need to check timing and the jetting on the carb.
Mon Nov 02, 2015 8:57 am |
Those numbers look low, although I'll admit not knowing what factory specs were for this altitude. My 302 came in at 110 across all the cylinders give or take a few psi.
Mon Nov 02, 2015 9:59 am |
colby45
They could be low. I honestly don't know. It probably needs a rebuild.
Mon Nov 02, 2015 10:13 am |
colby45
Yep, doing some quick research, that is awfully low so I think it's time for a rebuild. Anyone have any recommendations for someone who can do it for a reasonable price?
Mon Nov 02, 2015 10:38 am |
I'm dropping of TFB's 351w to a independent builder soon, I'll ask if he will a do straight 6.
Mon Nov 02, 2015 11:56 am |
colby45
Mon Nov 02, 2015 12:02 pm |
