It is currently Fri Nov 01, 2024 4:40 am
[ 11 posts ] |
trans tunnel floor support channel
I will be removing the NP435 from my 66 and replacing it with the correct 3 speed. I need some floor support channel to replace what was cut out to install the NP435 (top section, most of the driver side & a few inches of the passenger side). If someone is cutting this out of a truck or has a scrap tub with a decent section of channel.
If there was a complete dog house & channel run available, that would be ideal.
JBG lists the item as 66/67 specific, but I don't know what the difference is from the newer trucks. The rough dimensions are the same as my 74's channel, so I think I can use parts from any truck to do my patch.
Thanks
Sat Dec 05, 2015 12:31 pm |
Re: trans tunnel floor support channel
The forward support? I just cut a chunk out of mine. I can measure it if it will work for you.
Sat Dec 05, 2015 3:44 pm |
Sat Dec 05, 2015 4:39 pm |
6 1/8" wide. It's basically just the top section. None of the side piece. Based on you're picture, guessing it isn't enough.
Sat Dec 05, 2015 5:24 pm |
Its not quite enough, but hang onto it please. If I can't find a whole piece, maybe I can splice it together. Nobody's ever going to see it.
Sat Dec 05, 2015 7:13 pm |
Sat Dec 05, 2015 8:01 pm |
I've got this left over from a recent set of floorboards I did. Yours for the taking. It's pretty close to your drawing. I'd be happy to measure stuff if it'd help.
Sat Dec 05, 2015 10:05 pm |
Awesome, that looks about perfect! Thank you.
Sat Dec 05, 2015 10:08 pm |
Cool, it's yours. When do you need it and what's the best way to get it to you? Happy to ship if that's the plan.
Sat Dec 05, 2015 10:15 pm |
No hurry at all. Plans are to have it off the frame & blasted next summer. So sometime before July or August would be fine. LOL.
The first priority is getting the 74 running.
Sat Dec 05, 2015 10:31 pm |
Cool. I'll stick it on the shelf. It'll be here when you're ready.
Sat Dec 05, 2015 10:33 pm |
[ 11 posts ] |
Users browsing this forum: No registered users and 90 guests |
