www.ColoradoClassicBroncos.com - View topic - Dana 44 gears
It is currently Fri Nov 01, 2024 4:38 am
Reply to topic  [ 8 posts ]
 Dana 44 gears
 Dana 44 gears
I am looking for a complete ring and pinion for the front end it needs to be 4:10 gears. I can replace the bearings if I need to. Thanks everyone happy holidays :-)
Mon Dec 14, 2015 10:46 pm
Post Re: Dana 44 gears
If you need one there is a moderate chance that I've got the correct carrier for those gears. If you're going from stock 3.5 a change of carrier is needed.
Mon Dec 14, 2015 11:45 pm
I believe that it has 3.73 gears in it. Will that carrier work for 4.10 gears ?
Tue Dec 15, 2015 8:33 am
No, that's where the carrier break is. 3.73 and down is one carrier, anything above that is another. They also make thicker gearsets to allow you to run higher gears on the carrier you've got.
Tue Dec 15, 2015 9:34 am
Ok I understand that thanks for the help. I would like to start looking at pricing and availability. Who or where can I look to find one? What should I put in ? Is any brand better than another ? I like the factory set up it seems to do well but then I think about just upgrading to a air locker.
Thoughts ?
Tue Dec 15, 2015 2:35 pm
If you ever think you're going to do a locker, now is the time. 4 wheel parts or any of the EB vendors houses will have the needed gears and setup kit. The vendors might not carry the thicker gears needed if you don't replace the carrier.
Tue Dec 15, 2015 6:32 pm
Are you still looking for this?
http://denver.craigslist.org/pts/5336412775.html
Sat Dec 19, 2015 10:13 am
Sat Dec 19, 2015 11:10 am
Users browsing this forum: No registered users and 62 guests
32,739,968 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
